  • July 14, 2025, 10:05:16 AM
Author Topic: can foam-safe CA be used on balsa?  (Read 1391 times)
« on: August 05, 2017, 06:43:53 PM »
I just realized the thin CA I bought for $9 bucks at the LHS today is foam safe. Can it dependably be used on balsa? I've never used it before and haven't opened the bottle. It's not BSI either. I didn't pay enough attention.
Rusty
Re: can foam-safe CA be used on balsa?
« Reply #1 on: August 05, 2017, 07:21:21 PM »
  I think you will be OK. I have never heard of it not working on "typical" hobby materials after working 35 years at a local hobby shop and selling gallons of the stuff. I think some use it on clear plastic like canopies because when it kicks off, it doesn't fog the plastic.. It doesn't give off the fumes that bother some people either.If it's a long drive back to the hobby shop, and you have alternatives, just tuck it away along with the receipt and exchange it on your next trip, as long as you haven't opened it, of course.
Offline ray copeland
« Reply #2 on: August 05, 2017, 07:31:58 PM »
Rusty, that's all I have used for years. My sinuses wont take the regular fumes. It will work just fine.
« Reply #3 on: August 05, 2017, 08:46:57 PM »
Rusty
  It's the same active ingredient with a different solvent. It works fine, for the most part.
« Reply #4 on: August 05, 2017, 09:57:35 PM »
More spendy, just as strong, doesn't mess up your nose.
« Reply #5 on: August 05, 2017, 11:28:05 PM »
Oh, good. Thank you guys for the replies. I do get upper respiratory problems the day after a session of using thin CA. It's like I have a bad cold. So I'll go ahead and use it.
That's what I needed to know,
Rusty
