Actually, the Blue head is a .29. The Orange/Red head is a .33. There's also a Purple head .60, a Gold head which is a .19 or .23, and rumors of a Green head, IIRC. There are plain aluminum headed versions of all of them, except I've yet to see a silver head .33.
I don't like the crock pot method. It's too random and uncontrolled. You never know if the antifreeze is going to discolor the case of the engine you're trying to clean. Not to mention it often removes anodizing. I prefer to use spray carb cleaner, or acetone and an old toothbrush to clean the exterior. For sticky engines, I use a combination of heat (heat gun) and lighter fluid. The heat softens the castor, the lighter fluid thins it out and frees up the moving parts. I also pay special attention to the wrist pin. Most of the time if the piston is stuck in the cylinder, the pin is stuck to the connecting rod.
I've got a FRV Blue head .29 and a .33... They're not very strong engines, about equal to a sad .15. They wouldn't be my first choice to power a new plane, even when the selections are limited to ignition engines in the same size range. At least they're light and they start easily.
