  • July 07, 2025, 01:47:19 AM
Author Topic: Can't post a PDF image  (Read 1225 times)
Offline Dick Pacini
« on: November 15, 2010, 08:26:20 AM »
I have a PDF image that I want to post but can't figure it out.  Any ideas would be welcome.
AMA 62221
Offline Mike Anderson
Re: Can't post a PDF image
« Reply #1 on: November 15, 2010, 08:43:09 AM »
Hit Reply or "New Topic"
Click the "+" button labelled Additional Options
Click the "Browse" button and navigate to your file & click Ok
Complete your message and click "Post"
It should upload your file and attach it to your message.
Good luck --
Mike@   AMA 10086
Central Iowa
« Reply #2 on: November 15, 2010, 08:48:57 AM »
That is if it is not too big.  If it is your program should be able to resize.  Once resized do a save.  I have this site,  SSW and Barton that no two call for the same size.  I have a Kodak program on my coputor.   H^^
Offline Dick Pacini
« Reply #3 on: November 15, 2010, 08:56:00 AM »
Good luck --
I tried that a couple of times and nothing happened, although I never made the post.  It didn't show in Preview.
AMA 62221
« Reply #4 on: November 15, 2010, 09:32:36 AM »
Dick,
The file is either too big, or is corrupt in some way. If you like, you can send it to me and I'll see if I can fix it. Or several other guys here.
« Reply #5 on: November 15, 2010, 09:46:14 AM »
It doesn't show in the "Preview" because it won't be uploaded until you hit "Post" -
As long as your file is less than 1 Mbyte, it should be OK, but you do have to hit the "Post" button.
If it still doesn't work, you can "Remove" the post and try to fix the problem.
Mike@   AMA 10086
Central Iowa
Offline Dick Pacini
« Reply #6 on: November 15, 2010, 10:40:05 AM »
OK, I was able to post the link.  Apparently, a PDF file can't appear in a post without the (interested) reader clicking the link, downloading and then opening it.
AMA 62221
Offline John Harold
« Reply #7 on: November 15, 2010, 02:47:23 PM »
Depending on your version of Adobe, there is a "Copy To Clipboard " command in the Edit drop down. Once the image is in the Clipboard, open Paint, paste the image and save it as a JPEG. Resize if necessary and post it on here.
Using the Clipboard enables you to change images or drawings from a PDF to more forum useable JPEG or Bitmap....John.
« Last Edit: November 15, 2010, 05:09:51 PM by vauxhall »
« Reply #8 on: November 16, 2010, 09:42:36 AM »
As long as the wife, daughter or grandkids don't delete the program I have not had trouble loading pictures.  I down load the card from the digital camera to my pictures in the documents section of the computor.  I have Windows something that is working until the wife tries loading a newer version of windows.  I come to the forum,  start a new post or click on an existing post.
At the bottom of the post is a line "Additional Options",  click on it.  A line should come saying Attach:  with a blank space.  Click on the Browse.  Should bring up your picture file.  Check size of file/picture.  Has to be less than 1000KB.  If you have multiple files/pictures they need to be less than 200KB for 5 items.  The Attach shows that a max of 20 items as long as they don't add up to 1000KB.  My program has an edit in whitch I can resize.  I have to go 20% to get my items to size.  Click on the item you want to post.  The blank line in your pictures should have a location for your pic.  There is a box in  my program that you click on to tell wat type file you have.  Then click on open.  If you want more pics, click on more attachments.  I learned a lot of this by trial and error.  I too have some posts out in cyber space floating around.  Hope this helps a little.  At first it was very complicated for this old man. As time goes on it gets easier. H^^
PS:The attached was sent to me on Veterans Day.  jeh
Offline Bob Kruger
« Reply #9 on: November 16, 2010, 05:03:26 PM »
Dick;
If you are still having trouble, email it to me.  I will convert it to jpg and send it back to you.
V/r
Bob Kruger
Bob Kruger
AMA 42014
Offline Dick Pacini
« Reply #10 on: November 16, 2010, 07:35:51 PM »
Dick;
V/r
Bob Kruger
Can you download it from the other thread?
AMA 62221
