  • July 15, 2025, 11:25:00 PM
Author Topic: Calling Mike Pratt  (Read 1285 times)
Offline Gerald Arana
Calling Mike Pratt
« on: June 20, 2015, 07:14:58 PM »
What is the date of your Sig "Magnum"? Is it N-30, Classic........?
Thank you, Jerry
Anybody else feel free to chime in. y1
Jerry
Re: Calling Mike Pratt
« Reply #1 on: June 20, 2015, 07:23:17 PM »
Thank you, Jerry
  Pretty darn close for Nostalgia-30, no way for classic. 85 or 86, as I recall, first mainstream kit intended for an ST60 or 4-stroke.
« Reply #2 on: June 20, 2015, 08:28:04 PM »
Thank you Brett.
See you in Woodland, Jerry
Offline MikeyPratt
« Reply #3 on: June 20, 2015, 08:45:49 PM »
Thank you, Jerry
Jerry
Hi Jerry,
Yep, 1985 should be getting really close for the Sig Magnum.  Brett was right on target.  Designed in the fall of 1983
and kited in the spring of 1985.  The first version was built in winter of 77 & 78 which was a little different with the I Beam wing.
I hope this helps.
Later,
Mike Pratt (Mikey)
« Last Edit: June 21, 2015, 05:06:34 PM by MikeyPratt »
« Reply #4 on: June 20, 2015, 08:49:30 PM »
Thank you! By the time I get it built it will be well into N-30!
Cheers, Jerry
