  • July 18, 2025, 12:13:28 AM
Author Topic: Skip's Pinto  (Read 2678 times)
Offline Skip Chernoff
Skip's Pinto
« on: March 06, 2017, 05:39:13 AM »
I flew my new Pinto yesterday. She flew great. 10.5 ounces,Monokote finish,no landing gear (flying on grass) .008 linesx42' ,G Mark .061 on 25% fuel. 5x4 Cox Grey prop. Needs a bigger tank. Was using a Perfect 3/4oz wedge. I highly recommend this little 1/2A stunter. Wish I knew how to resize my pics so I can post them....PhillySkip
Re: Skip's Pinto
« Reply #1 on: March 06, 2017, 08:31:28 AM »
Don't you have a picture program on your computer?   That is how I do mine after down loading from camera.
Re: Skip's Pinto
« Reply #2 on: March 06, 2017, 10:00:30 AM »
Doc ,I suck at this computer stuff. I'll try to figure it out.
Offline Bob Hudak
Re: Skip's Pinto
« Reply #3 on: March 06, 2017, 10:10:29 AM »
Skip,
 Google Picture resize Genius. It's a free download and a no brainer to use.
Hope this helps.  Bob
350838
Offline Target
  • C/L Addict
Re: Skip's Pinto
« Reply #4 on: March 06, 2017, 10:35:53 AM »
Chris
AMA 5956
Re: Skip's Pinto
« Reply #5 on: March 06, 2017, 05:39:52 PM »
Thanks all I'm working on the picture thing. Today, we had a beautiful day here in Philly(very little wind) and I flew the @#$% out of the Pinto. My pal Rich Martinez got some pics and video. I'm sure he'll post it up shortly.  PhillySkip
Re: Skip's Pinto
« Reply #6 on: March 06, 2017, 07:45:39 PM »
Attached is a pic of my just finished Pinto .Engine is a GMark .061 on Foremost mount which required a complete redesign of front end. C/L will be 42' .008. The all up weight is 10.75 oz, covering is MonoKote. I didn't use the engine beams and added 1/16 ply doublers running back into the fuse /wing area. Tank is a 3/4 oz perfect wedge on suction. Hope you like it...PhillySkip
Offline Phil Spillman
Re: Skip's Pinto
« Reply #7 on: March 06, 2017, 08:13:53 PM »
Hi Skip, Great picture! Nice to see someone in PA having fun for a change instead of shoveling ....Partly Cloudy! Are you going out to Lebanon's Swap Meet this Saturday? I plan on coming up with an old friend to try to sell some of my stuff! Perhaps I'll see you there!
Phil Spillman
Phil Spillman
Re: Skip's Pinto
« Reply #8 on: March 06, 2017, 08:22:30 PM »
Yes Phil ,we'll be there,look for you. BTW Philly guys always have a good time!
Re: Skip's Pinto
« Reply #9 on: March 07, 2017, 11:06:49 AM »
I see you must have found a way to resize pictures.   Plane looks good, H^^  but look mucho better with a cute lady holding it. LL~ LL~
Re: Skip's Pinto
« Reply #10 on: March 07, 2017, 04:38:23 PM »
Doc, my wingman Rich posted them on the PhillyFliers facebook page. I clicked on the pic and moved it to my desktop. This forum accepted it from my desktop. facebook must resize the pics automatically.
Regarding getting a pretty girl to hold the plane for the shot... I contacted Sophia Vergara . She declined saying that should we meet  in person she wouldn't be able to control her passion for me and who knows how that would end???
Re: Skip's Pinto
« Reply #11 on: March 07, 2017, 04:47:24 PM »
Send Sophia the picture of the Pinto...maybe she'll reconsider. Clean it well, because apparently, she's fussy about greasy kid's stuff.  H^^ Steve
Offline paw080
Re: Skip's Pinto
« Reply #12 on: March 07, 2017, 08:04:35 PM »
Hello Skip, I like your 1/2A Pinto; the side mounting is very clever. I'm surprised your model
 weighs only 10.75 ozs.  I'm not sure of your final fuel tank capacity, but it will probably only
add an additional .5ozs.  I've got an older RSM Pinto kit, and I intend to power it with a
PAW .5cc diesel engine. My projected ready to fly weight, sans fuel, should be right at 7.0 ozs.
If I'm lucky I might get the weight down to 6.5-6.75 ozs.  Unlike you, I intend to use the 1/32"
sheet for planking. Don't be afraid of 1/32" sheet wood. I have built many Fast Combat ships
with 1/16" planking for wing leading and trailing edges.  I'll use Jap Tissue for covering and use
appropriate grained 3/32" sheet balsa for empennage and flaps.  With diesel power, I can use a
significantly smaller fuel tank than a glow engine requires.  I have considerable experience with
small diesel engines in Pinto sized models. My modified Ringmaster Jr's have stock airfoils, tail
 moments, but have shortened nose moments to accommodate smaller tank dimensions  and much
lighter airframes.  The PAW 0.80cc engines get approx. 7 minutes airtime on 2/3 oz capacity tanks.
Their ready to fly weight is 7.2 oz's sans fuel. These Ring Jr's turn very sharp and can stay overhead
on 44'X .008" lines.
I hope to start construction in about a month(construction area is in disarray due to building updates). S?P
Tony ;D
Re: Skip's Pinto
« Reply #13 on: March 07, 2017, 09:30:46 PM »
Tony, because I used the Foremost motor mount I eliminated the engine beams.I did however install 1/16 doublers to the fuselage sides as per full size stunters and some triangle stock at the firewall. I eliminated the landing gear as we fly off grass. The tank is a 3/4oz Perfect wedge on suction only. I was surprised by the light weight of the finished plane as well.BTW I did use the 1/32 sheeting as per plan,but if I built another I'd probably use 1/16.  The gMark engine was a good choice .It is very steady with good fuel draw.If you go to the Philly Fliers facebook page there is a video of me flying it....PhillySkip
Re: Skip's Pinto
« Reply #14 on: March 08, 2017, 07:39:46 AM »
Sophia contacted me and said she's looking for something a little bigger that a Pinto.....wink wink....Cheers,PhillySkip
