  • July 06, 2025, 05:25:01 AM
Author Topic: PAMPA January - February 2013 "Stunt News" is Available for Download  (Read 1002 times)
Offline Bob Kruger
The January - February 2013 PAMPA "Stunt News" is available for download for current PAMPA members.
The January - February 2013 "Stunt News" includes:
- Igor Burger's "Max Bee"
- "A Champion's Motivation" by P. J. Rowland
- Bob Duncan's Ford Tri-Motor in "Appearance Point"
- Plus District and International Reports, Contest Results, and much more.
To download the January - February 2013 "Stunt News", make sure you are logged into the PAMPA Website and go to http://www.control-line.org/DesktopDefault.aspx?tabid=91 .
Bob Kruger
AMA 42014
Offline Dan Bregar
  • Field Marshall
Re: PAMPA January - February 2013 "Stunt News" is Available for Download
« Reply #1 on: February 12, 2013, 04:49:44 PM »
Hey Bob----Am I the only one having a problem opening the download ?  :)
AMA 33676
Offline Dan Bregar
  • Field Marshall
« Reply #2 on: February 12, 2013, 05:46:59 PM »
Never mind, I got it to work.  :-[
AMA 33676
« Reply #3 on: February 12, 2013, 11:51:18 PM »
Oops.  The contest calendar got left out of this issue.  Attached is the latest.
« Last Edit: February 13, 2013, 11:44:56 AM by Howard Rush »
Offline Gary Mondry
« Reply #4 on: February 13, 2013, 10:51:05 AM »
Great to see PAMPA Plans Service back up and running in this issue.  I've been waiting to order.
AMA 10663
Offline Bob Kruger
« Reply #5 on: February 13, 2013, 11:38:44 AM »
Dan;
Usually the day the magazine is published on line the server supporting the site gets a little bandwidth stress.  That normally evens out after a couple of days.  If you still can't get it after a couple of days, I will go and try to chase down a technical solution.  Regrettably, the offshore Mumbai based tech support often makes changes with neither adult supervision nor thorough testing to ensure there are no second and third order effects on site functionality.  It is why we are building a new site with a new provider.
V/r
Bob
Bob Kruger
AMA 42014
