  • July 13, 2025, 08:20:55 PM
Author Topic: K&S SMG or 00?  (Read 1389 times)
Online Juan Valentin
K&S SMG or 00?
« on: April 25, 2014, 09:41:33 AM »
Hello
               Which is best for covering solid surfaces and fuselage? I was able to find some in a local hobby shop and would like to use it on my Dolphin.
Online RC Storick
Re: K&S SMG or 00?
« Reply #1 on: April 25, 2014, 10:04:44 AM »
Hello
Re: K&S SMG or 00?
« Reply #2 on: April 25, 2014, 10:42:21 AM »
Offline Michael Boucher
Re: K&S SMG or 00?
« Reply #3 on: May 03, 2014, 08:13:34 AM »
What's the best type for the wing if 00 is the best for fuselages and tails? Thanks
AMA 59633
Re: K&S SMG or 00?
« Reply #4 on: May 03, 2014, 03:22:43 PM »
Polyspan!!!  y1 y1 #^
Re: K&S SMG or 00?
« Reply #5 on: May 04, 2014, 02:46:12 PM »
Hi Michael,
The SGM on the open bays.  It is a bit tougher than the OO.  I agree, though, use polyspan on open bays if you have it.  MUCH less likely to get those pesky holes in it from hanger rash. ;D
 BIG Bear
RNMM/AMM
Re: K&S SMG or 00?
« Reply #6 on: May 04, 2014, 07:07:56 PM »
Hello Michael
                     Like the guys said you can use SGM,Polyspan or SLC plastic covering.I have done a Ringmaster with SLC and I`m waiting to have it under the hot sun to see if it sags or bubbles since is the first time I use it. I have used Polyspan but if you don`t fill all the weave with 3 coats of clear you get some very obnoxious fuzzys,I think Bill Little told me to use CA on those spots and sand them.
Offline George
  • Love people, Use things.
Re: K&S SMG or 00?
« Reply #7 on: May 11, 2014, 10:14:06 AM »
Mike,
If you use SMG (Super Models Gas) on open wing bays be sure to apply it span-wise.
Tear a small corner piece that you are not going to use parallel to the edge in both directions. The smooth tear is span-wise. This will produce less sag as well as a lot more strength and tear resistance between ribs.
If it is a large plane you might want to consider a synthetic as others have mentioned.
George
« Last Edit: May 11, 2014, 10:42:13 AM by George Bain »
George Bain
AMA 23454
