  • June 29, 2025, 01:00:48 AM
Author Topic: New Enya 32CXL Rear Exaust  (Read 2567 times)
Offline Martin Quartim
    • StuntHobby
« on: April 15, 2009, 06:11:56 PM »
Enya just released a new engine for CL and this one has a Rear Exhaust.
http://www.enya-engine.com/32CXL_E.html
Now Enya has a total 22 Engines for C/L including the Diesel ones.
Martin
Re: New Enya 32CXL Rear Exaust
« Reply #1 on: April 15, 2009, 06:52:10 PM »
looks good - wish they would do the 61 in RE......
Offline Allan Perret
  • Proverbs
« Reply #2 on: April 15, 2009, 07:21:36 PM »
Think Stalker 40, 51, 61, 66, 76..
Allan Perret
AMA 302406
Slidell, Louisiana
    • StuntHobby
« Reply #3 on: April 15, 2009, 08:34:01 PM »
You know, they'll probably make it. The Enya 61CX was built around the 45CX case and they have the 45CXL with rear exhaust, not in production though. I have asked Ken to make the 61CXL and he said it could be done but it seems there is a problem getting the special aluminum alloy Enya uses to make the 61CX pistons, and that 's why they don't have the 61CX in stock now. I hope they'll make it.
Martin
« Reply #4 on: April 15, 2009, 11:48:38 PM »
think $$$$$$$$$$$$$$$$4  I had a stalker 66RE - nice motor - but LOTSA money (for me anyways)
  • Proverbs
« Reply #5 on: April 16, 2009, 06:08:39 AM »
The new Enya 32 RE looks like it will be around 150 depending on exchange rate, without muffler.  Last time I checked Stalker 40 RE with muffler was around 200, and the Stalker is a dedicated stunt motor.  Not sure about the new Enya, not to say it wont work good for stunt.  But first you gotta get the header which is not yet available ( I sent an e-mail to Ken Enya, he says they will "soon release" a header, but no muffler), then you will need to wait for someone to start making a muffler to fit it, typically around $40..  So you will likely need to add $55~60 to cost of the Enya for comparison.    But it sure is cute, I will likely get one myself, probably build a Nobler around it.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Gordon Tarbell
« Reply #6 on: April 16, 2009, 06:10:14 AM »
looks like at least two different versions of this 32. I wonder what the differences are? Just a carb swap (RC or venturi) ,maybe rpm range. With a two piece head I wonder if different buttons are going to be available for different fuels (nitro fuels and no nitro fuels). Didn't see a weight listed either.  Looks nice.
Gordon Tarbell AMA 15019
  • Proverbs
« Reply #7 on: April 16, 2009, 06:26:07 AM »
Click on the "Info" link on Enya's site.  Ken Enya will answer all your questions..
Allan Perret
AMA 302406
Slidell, Louisiana
    • StuntHobby
« Reply #8 on: April 16, 2009, 10:00:46 AM »
Randy Smith might have  head muffler that will fit the Enya for less then $40.  And please correct if I am wrong, but I thnk a high revving Enya 32 would be more comparable to Stalker 46~50.
Martin
    • StuntHobby
« Reply #9 on: April 16, 2009, 12:37:54 PM »
I just got an official note from Enya that there are 2 new Enyas 32 for C/L. The 32CX S Pro with Side Exhaust and it comes with muffler and the Enya 32CXL S Pro Rear Exhaust that comes without a muffler and it cost less.
Weight Without Muffler
32CXL S PRo 8.18 Oz
32CX S PRo 8.15 Oz
The exhaust header for 32CXL is being produced now and it will be optional.
Martin
  • Proverbs
« Reply #10 on: April 16, 2009, 01:15:48 PM »
Martin
I have a Stalker 51 but have never run it, so I cant say for sure.  I have read where several others using it in 600~650 in^2 ships around 55oz and getting great stunt runs.  I cant imagine any 32 doing that even on a pipe.  But we shall see.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #11 on: April 16, 2009, 03:18:04 PM »
Allen,
Hmmm, I dunno. Phil Granderson used a Magnum 36 on a pipe to fly his 650+ square inch Diva. But you're right, a 32 is probably too small. That's why I want a 40VF clone.
  • Proverbs
« Reply #12 on: April 16, 2009, 05:17:33 PM »
Allen,
I didnt realize the Diva was that big.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Ed Prohaska
« Reply #13 on: April 17, 2009, 08:49:00 PM »
If the header to the Stalker .40 RE fits the Enya, a Stalker muffler could be used. EWP
