  • July 14, 2025, 04:35:35 AM
Author Topic: BuiltRight Flyright Sakitumi-E  (Read 15849 times)
Offline badbill
« on: November 22, 2016, 12:54:14 PM »
Just finished my BuiltRight Flyright Sakitumi-E. Nicest kit I ever built, I think it will fly good  y1 Cobra 2826/10 with a Ressinger/Cox 12 x 5  reverse pitch three blade prop. Hyperion 4S 3300mah Lipo, FM9 set at 9500 RPM.
Bill Davenport
AMA 28141
Offline badbill
Re: BuiltRight Flyright Sakitumi-E
« Reply #1 on: November 22, 2016, 03:57:26 PM »
Just weighed it. The Plane is 36.7 Ounces, the lipo is 11.5.  Also just got in a TP Lipo for it that is only 10.2 ounces. Coming up nose heavy with either one. I'll fly it first before adding any tail weight or changing anything.
Bill Davenport
AMA 28141
Offline Brent Williams
« Reply #2 on: November 22, 2016, 04:28:49 PM »
Really nice plane!
I am no E-power expert, but I wonder if you will really need a 3300Mah battery for that setup.  It's fairly light and not terribly draggy being flapless.
I wonder if you might be able to get away with a lighter 2700mah.
In a recent thread in the electric forum, Crist Rigotti outlined in a spreadsheet the setup for a 50oz plane using a 4s 2700mah battery.
http://stunthanger.com/smf/gettin-all-amp'ed-up!/pathfinder-setup/
Offline badbill
« Reply #3 on: November 22, 2016, 04:43:01 PM »
Lots more experimentation to go, but short answer is YES, if I stay with this prop I will definitely need a battery at least that size. I may not stay with it though.I also have the RPM to play with, which I may do. Let's see how it flies first. FYI, my talks with Bob Hunt led to this setup.
Bill Davenport
AMA 28141
« Reply #4 on: November 22, 2016, 08:52:47 PM »
 Looks great Bill, I like the clean and simple scheme, should be a great flier too.  y1
Offline Mike Griffin
« Reply #5 on: November 23, 2016, 10:06:17 AM »
Hey my old Georgia friend... this looks great...I miss the days at Mac's talking with you.  Have a good Thanksgiving Bill.
Offline badbill
« Reply #6 on: November 23, 2016, 10:21:51 AM »
You too bud, those were the days. I miss running the hobby shop a lot, but it was a pretty rough job many times. New one is much closer to home and easier too  <=
Bill Davenport
AMA 28141
Offline Jim Svitko
« Reply #7 on: November 23, 2016, 10:53:26 AM »
Nice looking plane, I like the red color.  Let us know how it flies.  I would be interested in such info since it is has no flaps.
I am not a fan of profiles so maybe one of these with a built up fuselage?
Offline badbill
« Reply #8 on: November 23, 2016, 11:09:30 AM »
I'll know soon, hopefully. I can't believe no one has said anything about the landing gear LOL...   y1
Bill Davenport
AMA 28141
Offline RK
« Reply #9 on: November 23, 2016, 12:05:24 PM »
   ;D Hey Bill.....What did you use to make the landing gear??
If you come to a fork in the road,,,,Take it!
Offline badbill
« Reply #10 on: November 23, 2016, 01:10:21 PM »
That's better! My buddy at work did it on the CNC machine  :P
Bill Davenport
AMA 28141
« Reply #11 on: November 23, 2016, 02:05:11 PM »
I hope she flies as well as she looks.  One gorgeous plane. H^^
Offline jfv
« Reply #12 on: November 23, 2016, 02:43:16 PM »
Very nicely done!
Jim Vigani
Offline BYU
« Reply #13 on: November 24, 2016, 07:57:59 AM »
That looks AWESOME!!! Superb.
Offline badbill
« Reply #14 on: November 27, 2016, 01:32:01 PM »
Flew it twice today, and it is a winner. I forgot to put any weight in the tip box, and it does need it. With the Thunder power lipo it balanced better and flew just great, but it still flew fine with the heavier Hyperion. At the end , both batteries checked with 46% remaining, so I'm going to dial up flight time and RPM a bit, with the goal being 18-20% remaining.  I am pumped, love it!
Bill Davenport
AMA 28141
« Reply #15 on: November 27, 2016, 03:25:31 PM »
Did you fly full patterns on those flights?  What was the flight time?
Offline Jim Svitko
« Reply #16 on: November 27, 2016, 03:40:43 PM »
After reading the specifications of this plane I would think that for glow power something like the LA 46 would be a good fit.  Or, is the LA 46 too much?  If anyone is flying one with glow power what engines are you using?
« Reply #17 on: November 27, 2016, 03:49:33 PM »
Nice looking airplane.  Too bad it has all those electronic gizmos cluttering up the fuselage!  LL~ LL~ LL~
« Reply #18 on: November 27, 2016, 03:59:27 PM »
Hey Randy according to his site there is a SAKITUMI profile nitro version.   35-46 engine  55.5" span  621 sq. in.   Prototype was 38 oz.
May get one for the LA 46 to stash away.
« Reply #19 on: November 27, 2016, 07:12:12 PM »
Mine was covered in yellow silk and I gave it to a young guy starting out down in Rolla, Mo. I think he gave it or sold lit to a buy in St Louis, as I have seen it since.  D>K
[/quote]
   Hey Ty! Guess where it is now!!!???  Hanging in my garage. I swapped an Evo .36 for it and the LA.40 in the nose that needed work. I got it set up and trimmed to my liking now with an LA.46 in the nose to get some experience with that engine. Great combination. I flew it in Expert at the Brickhaus contest in Paducah this past August, but you weren't there. I just recently found out from Ed, the guy you gave it to, that it was your airplane. He dinged it up a bit but still flies great. I got a kit and hope to build it soon and include the wheel pants and stuff, and make it look as much like the last airplane Leo Loudenslaeger was building when he died as a result of injuries from a motorcycle crash. I'll get to that as soon as I get some other stuff out of the way and the building room cleared out. I'll have to take a picture and send it to you.
Offline badbill
« Reply #20 on: November 28, 2016, 04:54:34 AM »
Nope, even if I could do the full pattern I wouldn't do it on test flights  #^ First flights were 4.5 minutes, they will end up at probably 5.5 minutes.
Bill Davenport
AMA 28141
Offline badbill
« Reply #21 on: November 28, 2016, 07:55:48 AM »
I think an LA 46 would be just right, power edge would go to the electric though  >:D Either way would be fine. When he gets back on his feet I may order a nitro kit...
Bill Davenport
AMA 28141
Offline Dane Martin
  • heli pilot BHOR
« Reply #22 on: November 28, 2016, 08:09:48 AM »
The plane is 36 oz now, I would assume lighter on glo. A .46? Goodness you guys love the HP! Lol.
I'm thinking whip or rubber power is sufficient!
Offline badbill
« Reply #23 on: November 28, 2016, 08:36:38 AM »
Little bit too windy around these parts to fly lightly powered airplanes, and I can't stand flying a plane that won't stay out at the end of the lines well anyway  %^@ My Primary Force ARF has a LA46 and it is about perfect  LL~
Bill Davenport
AMA 28141
Offline Target
  • C/L Addict
« Reply #24 on: November 28, 2016, 07:53:26 PM »
I'm wondering if you went down to an 11" or so prop, you could probably get by easily with a 2800 pack.
But, maybe conditions in sunny (?!) SoCal are easier than where you are, Bill.
Glad you got in on that Thunder Power sale. prices were attractive to say the least.
Vr,
Chris
Chris
AMA 5956
Offline John Rist
« Reply #25 on: November 29, 2016, 10:17:47 AM »
Not sure when Walter can supply me a kit But this will be my next airplane.  I am sure it will be worth the weight.   #^   #^   #^   #^
Offline badbill
« Reply #26 on: November 29, 2016, 11:15:26 AM »
Funny thing about this is, me too. I really want to build another one, and I have a LA .46 ready and waiting. Maybe this time I can make it look nice  #^
Bill Davenport
AMA 28141
Offline John Rist
« Reply #27 on: November 29, 2016, 06:07:34 PM »
I will build the E power version. I plan to use a Cobra 2826/10 on a 4 cell pack.
Offline Jim Mynes
  • Chelsea, ME
« Reply #28 on: November 30, 2016, 04:41:36 AM »
That's what mine will have.
I have seen the light, and it’s powered by a lipo.
Offline badbill
« Reply #29 on: November 30, 2016, 04:42:37 AM »
It's a good choice, I am real happy with it.
Bill Davenport
AMA 28141
Offline badbill
« Reply #30 on: December 25, 2016, 07:58:31 AM »
OK, finally yesterday I had the chance to get out for a day of flying with the Sakitumi. Final adjustments were adding the tip weight I had forgotten, moving the leadouts back, and setting the FM-9 for adjusted time and RPM. I ended up at 9880 RPM and flight time set at 5:45 min. with a remaining 22% in the lipo. The balance is perfect with the TP Lipos, a little nose heavy with the Hyperion but still flies great. The plane is soooo smooth and easy to fly- literally the same speed straight down as straight up. I believe I have been crippling my advancement in flying ability by not having smooth enough controls- this setup is effortless and it makes such a big difference. Also, this is my first plane with a 4 inch bellcrank, that may be helping too. Walter, thanks for an awesome kit and plane!!!
Bill Davenport
AMA 28141
Offline badbill
« Reply #31 on: December 25, 2016, 12:59:24 PM »
Here's a crummy video from this morning. No excuses, other than it was windy and I am still very ground shy with this plane. I really enjoy flying it. This was it's 7th flight, had ten when I left the field today.
Bill Davenport
AMA 28141
Offline Carl Cisneros
« Reply #32 on: December 25, 2016, 05:20:08 PM »
Very nice Bill
Smooth flyer ya got there.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Target
  • C/L Addict
« Reply #33 on: December 25, 2016, 05:41:27 PM »
Are you still on the 12 x 5 prop?
Looks and sounds very smooth!
Congrats and Merry Christmas!
R,
Chris
Chris
AMA 5956
Offline Dane Martin
  • heli pilot BHOR
« Reply #34 on: December 25, 2016, 07:49:46 PM »
Dee-zam! Very smooth Bill!
Offline badbill
« Reply #35 on: December 25, 2016, 08:15:45 PM »
Thanks guys. Yes, still using the Cox/resinger 12/5 three blade reverse pitch prop. Love it, very distinctive sound😎
Bill Davenport
AMA 28141
Offline John Rist
« Reply #36 on: December 27, 2016, 09:00:54 PM »
I have one of the  Sakitumi-E on order.  Does anyone have an update when Walter will be up and about and will be shipping kits?
« Reply #37 on: December 28, 2016, 10:44:48 AM »
Contact him.  He will answer calls and PM's. VD~
Offline badbill
« Reply #38 on: December 28, 2016, 12:01:10 PM »
The website says he is closed till Jan 4, 2017.
Bill Davenport
AMA 28141
Offline John Rist
« Reply #39 on: December 29, 2016, 07:51:24 AM »
Just received an eMail stating that he will up and running Jan 4.  That is good news!  Walter's contribution to our hobby is legendary.   #^  #^  #^
Offline badbill
« Reply #40 on: December 29, 2016, 12:04:22 PM »
Sent you a PM John.
Bill Davenport
AMA 28141
Offline John Rist
« Reply #41 on: January 20, 2017, 07:56:07 AM »
Received this eMail from Walter today:
"Hi John,
Sorry for the wait, am feeling better today but I have been down with a
pretty bad cold for the past week, so I haven't been able to get anything
done this week.
The good news is that when I woke up today I feel really good so I hope
to be able to say that I have shipped the last USA-1 kit.
More good news is that my new batch of wood came on Wednesday, so I
will be able to start sorting it over the weekend and with that said I am hopeful
to start on the waiting list sometime next week. I will most likely to start with the
Sakitumi kits, so if I can ask you to please hang in there just a little longer.
Thank you for your patience, you will not regret the wait
Walter"
SO as the monkey said when he got his tail caught in the lawn mower _ "It won't be long now!"   I am really excited to get started on my next build!    #^  #^  #^  #^  #^  #^
J Rist
Offline badbill
« Reply #42 on: January 20, 2017, 08:09:57 AM »
John,
              Please don't hesitate to contact me if you need any help / details about the build or setup. I have probably 35 flights on mine now and have changed several speed control and timer settings to get it just right. I could also send you the castle file for the ESC settings if you'd like, but it's only going to be good for using the Cox / Resinger prop. I also contacted him about getting another kit, but haven't heard back yet. Glad he is doing better!
« Last Edit: January 20, 2017, 08:39:38 AM by badbill »
Bill Davenport
AMA 28141
Offline John Rist
« Reply #43 on: January 20, 2017, 11:02:24 AM »
John,
Thanks for the offer of help.  However I use KR timers and TURNIGY Plush speed controllers.  I have had good luck with this setup in the past.  I would be interested in hearing what motor and prop you are using.  Especially the source for the Cox / Resinger prop.
« Reply #44 on: January 20, 2017, 11:31:51 AM »
Hi Doc,
Yeah I've been looking at one on His site for a long time.  May have to get one for fun stuff.  A good match for one of my RO Jett 40's I think!
Right now I'm still waiting for my USA-1 Kit from Walter.  I suspect He's still backlogged!
Offline badbill
« Reply #45 on: January 20, 2017, 01:47:14 PM »
 Cobra 2826/10 . Prop from  Alan Resinger. His email address is resinger  attt  telus  dawt  net
Bill Davenport
AMA 28141
Offline badbill
« Reply #46 on: January 24, 2017, 09:33:50 AM »
Well, I talked to Walter and ordered a Sakitumi Nitro. Can't wait to build it, This one will have an LA .46  #^  Will be fun to have the same plane both nitro and electric!
Bill Davenport
AMA 28141
Offline badbill
« Reply #47 on: March 12, 2017, 08:36:06 AM »
Here's some more Sakitumi-E video. Many flights now, still lovng it!
Bill Davenport
AMA 28141
« Reply #48 on: March 12, 2017, 09:19:23 AM »
Watched Dan McEntee fly his at the St Louis Ice-O-Lated and it made me think about getting one.   But, I need to start flying what I have already. H^^
Offline badbill
« Reply #49 on: January 05, 2018, 06:45:44 AM »
Here's a little update. Many, many flights on this Sakitumi-E now and still love it. In the next day or so I'll add on to here with some pics of my new, just completed nitro version. LA .46 powered, just finished it, no flights so far but it turned out great. Biggest surprise to me is that with no fuel in the tank, it only weighs one ounce less than my RTF electric version!
Bill Davenport
AMA 28141
