  • July 04, 2025, 01:04:26 AM
Author Topic: Building from Plans  (Read 2224 times)
Offline Jay Wood
Building from Plans
« on: July 25, 2009, 11:46:32 PM »
I have several plans I'd love to start on. But I need a bit of advice. How do you make the templates off the plans so you can begin cutting? Also is a small scroll saw the right tool to cut the parts needed?
Maybe I missed it but this might a good Forum topic
Re: Building from Plans
« Reply #1 on: July 26, 2009, 01:56:41 AM »
Hi Jay,
A couple ways of doing things are making a copy of the plans and cut them up, or pin pricking through the plans onto the wood.  I get copies from Staples for less than $5 for large plans.  I also measure a lot of things that are right angles and such and transfer the measurements straight to the wood.  I am sure there will be many more suggestions, but those have been the main things I do over the years.  I just remembered one more thing, and that is "C temp", or something like that, which I got from Tom Morris.  It is a thin, transparent plastic sheet that you can trace on then score with a knife and it breaks clean which is good for making templates from.
Bill <><
Offline Pinecone
« Reply #2 on: July 26, 2009, 06:44:52 AM »
See Temp - http://www.seetemp.com/
I picked up some at Toledo.  Nice stuff.  Seesm kind of a waste for a one off, but it is easy to use and works well.
Of course, one could start a lending library of templates. :)
Terry Carraway
AMA 47402
Offline Neville Legg
« Reply #3 on: July 26, 2009, 06:53:08 AM »
If you use a Solar Film iron on the back of a photocopy of the part, the heat will transfer the toner from the copy to the wood!
Or you can use 3M photo spray mount on the copy, stick the print to the wood cut around the copy into the wood then peel off the copy when you have the part to the right shape!
Cheers     Neville
(not) Descartes
« Reply #4 on: July 26, 2009, 07:51:27 AM »
Or he could do like I did.  Once I found out that laser cut parts were available I got the plans and then ordered the parts already cut.  Make for so much better assembly when parts are accurately cut.  DOC Holliday
Offline Tom Niebuhr
« Reply #5 on: July 26, 2009, 10:09:48 AM »
I hate to see good plans cut up, so I use tracing vellum in most cases. Or as stated above, make a copy to cut up (ouch) for patterns.
A sharp exacto knife and a metal straight edge are most valuable.
We can custom make laser ribs if we have a copy of the drawing. I have a growing Cad file of ribs for many airplanes.
AMA 7544
Offline Jay Wood
« Reply #6 on: July 26, 2009, 10:36:23 AM »
All,
Many thanks for the suggestions.
Doc, who did you use to cut your plans?
Tom, I'm guessing you have a laser cutter? If I sent the plans I'm guessing you could cut the ribs.
It's a C/L Me 110 from the AMA plans service.
Once again thanks to all
Offline Jim Thomerson
« Reply #7 on: July 26, 2009, 11:26:25 AM »
I have an antique artifact; carbon paper.  I put carbon paper between the plan and the wood and go over the part outline with a blunt point scribe (A ball point pen which doesn't write works for this.)
« Reply #8 on: July 26, 2009, 12:14:10 PM »
Jay, go to vendors corner on this forum, look for Action Hobbies/Laser Works.  They have several designs listed.  DOC Holliday
Offline Leester
« Reply #9 on: July 26, 2009, 12:48:11 PM »
Brodak sells rib sets to all their kits and at a good price. You could see if there Warbird set (48") wing is close and use it.
Leester
ama 830538
Offline Phil Coopy
« Reply #10 on: July 26, 2009, 01:00:21 PM »
Straight lines by measurements,  curves with carbon paper, sometimes you can duplicate curves easily with a set of french curves.
Phil
