  • June 19, 2025, 10:23:56 PM
Author Topic: My Latest, a Jr. Ringmaster  (Read 6107 times)
Offline badbill
« on: July 31, 2016, 12:17:54 PM »
My newest build of the planes I wanted as a youth but never had. This one is a Jr. Ringmaster from the PDK kit. It was excellent quality, and a very fun build. Powered by a MK 1 Tee Dee .15. Monokote on the wing, Lusterkote spray on the fuse, aluminum and missle red. Should be fun to fly, I think it will have enough power  :-)
Bill Davenport
AMA 28141
Offline Mike Griffin
Re: My Latest, a Jr. Ringmaster
« Reply #1 on: July 31, 2016, 12:36:34 PM »
Good work Bill.
Offline Fredvon4
  • Central Texas
« Reply #2 on: July 31, 2016, 12:48:20 PM »
Well done and great looking RM...I like it BadBill!
have fun keeping that baby under control with 4 or less second laps
Fred von Gortler IV
« Reply #3 on: July 31, 2016, 07:30:03 PM »
NEED VIDEO OF THAT FLYING!!
Offline Russell Shaffer
« Reply #4 on: July 31, 2016, 07:37:46 PM »
It sure does look nice.  And, yes, I think the power will be OK.  Ringmaster combat?
Russell Shaffer
Klamath Falls, Oregon
Offline pat king
    • PDK LLC
« Reply #5 on: July 31, 2016, 09:39:45 PM »
Nice airplane! It should be a rocket ship with the TD 15.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #6 on: July 31, 2016, 10:34:34 PM »
   My first "big" airplane was a Ringmaster Jr. - with a Supertigre G20/23!  Absolute bomb, more than 80 mph.
Offline Guy B Jr
« Reply #7 on: July 31, 2016, 10:48:40 PM »
Hi Bill,
What pitch is that prop? You might want to use low pitch on that engine with that light a plane. Looks great.
Guy Blankinship
Offline badbill
« Reply #8 on: August 01, 2016, 06:51:33 AM »
Hi Bill,
It's an APC 8/4. Engine will be kept rich, since it is ball/socket and not a MKII with a wrist pin.
Bill Davenport
AMA 28141
« Reply #9 on: August 01, 2016, 09:44:33 AM »
Let me know if you ever need that ball joint re-set. I have a special hammer for that.
If you put a piece of fuel tubing over the needle threads it will help seal. You could eliminate the spring clicker and put tubing over the whole thing.
Offline badbill
« Reply #10 on: August 01, 2016, 10:36:40 AM »
Already did the break in on it and it runs very well. If I have trouble with the settings I will do that, thanks!
Bill Davenport
AMA 28141
Offline Allan Perret
  • Proverbs
« Reply #11 on: September 27, 2016, 03:58:25 PM »
Great looking Junior.  Did you ever fly it ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline badbill
« Reply #12 on: September 27, 2016, 06:57:00 PM »
Yes, it has two flights now and does real well. Still needs some adjustments, less tail weight and less elevator throw. Quite fast!
Bill Davenport
AMA 28141
« Reply #13 on: September 27, 2016, 07:15:08 PM »
I don't know why I didn't look the first time around -- the clear on the wings looks very good.
  • Proverbs
« Reply #14 on: September 27, 2016, 07:51:42 PM »
Maybe try some longer lines.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #15 on: September 28, 2016, 11:43:00 AM »
I thought an .09 would be sufficient!
Chris...
Offline badbill
« Reply #16 on: September 28, 2016, 01:11:27 PM »
Chris...
I think the ideal motor would be an OS .10. I just wanted the same motor on mine the neighbor kid had on his back in 1969. And it really isn't that overpowered, I like fast and I am flying it on .015 52' lines.
Bill Davenport
AMA 28141
« Reply #17 on: September 28, 2016, 05:53:50 PM »
It's really pretty...and the structure is the way they should have done it in the first place. Good job, Bad Bill!
I'd look at APC's list and see if they don't have an 8-3, and order some up. Then too, I'd consider longer .012" lines. But I'm old and don't have good reflexes (still!).   H^^ Steve
Offline badbill
« Reply #18 on: September 28, 2016, 07:15:04 PM »
It's turning just short of 15k on the 8x4 Steve😎 Let's keep this motor in one piece...!
Bill Davenport
AMA 28141
« Reply #19 on: September 28, 2016, 07:50:33 PM »
Well, then how about a 9-3? Remember that you can re-pitch APC's, as well as carbon and wooden propellers!  D>K Steve
« Reply #20 on: September 30, 2016, 07:29:15 AM »
Beautiful job!
I built one in Junior High and put a Cox Sportsman 15 (with rear venturi) on it.  What a mean engine!  Always was biting me.  And then I guess it was nose heavy as it's loops always ended up plowing into the ground.  Back then we built what came in the box and if it flew, it flew.  Balancing?  What's that?  ???
« Reply #21 on: September 30, 2016, 01:18:05 PM »
I had a Ringmaster Jr in 1955 or 56 with an OK Cub .14 on it.  Just right for 52 ft lines.  I would actually fly the entire stunt pattern.
I actually was a Combat flier at the time and built the Jr just to learn the stunt pattern.  Good choice!
Offline John Rist
« Reply #22 on: September 30, 2016, 07:05:00 PM »
Be sure to fly it this weekend for the Ringmaster Fly-A-Thon
« Reply #23 on: September 30, 2016, 08:50:21 PM »
 That thing's gotta be a screamer!
 Looks great too, brings back memories of the Li'l Jumpin' Bean I had many years ago with a Missile Mist fueled Tee Dee .051.  VD~
Offline paw080
« Reply #24 on: October 01, 2016, 01:20:24 AM »
Hi, The Ring Jr has seen a lot of different power plants used by many different modelers through the years.
My first Ring Jr was built when they first came out(1954??).  I powered it with a Cub .099; it flew every thing
I could do then, insides, outsides, horizontal, vertical and overhead eights and wingovers.  I don't remember
the line sizes, probably 42' X .008"s.  In the late 1980s I built another one from a kit and remembering that
It flew really well with a Cub .099(power equal to a good Cox reed valve .049) I powered it with an AM 1.0cc
diesel.  It could easily fly a stunt pattern, first on 1/2A Combat lines(35' X .012"). then later on, I went to
44' X .008" stranded lines.  I built three more Jrs, one with an extended wing giving 260sq"s and two very
modified for the Paw .08cc(.049cu") plain bearing and single bearing engines.  The last Ring Jr weighs only
7.2ozs with engine,  1/2oz fuel tank and Cox grey 6 X 4 prop.   This last one flys the pattern very well and turns
very sharp corners. It also performs overhead maneuvers very well.
I've been sidetracked from building another Ring Jr, but with the Paw .80 cc or Paw 1.0cc diesels, I would boost
the wing area to 240sq"s.   I don't think my models are real Ring jrs anymore, but I did keep the wing construction,
wing area  and tail moments the same as the original design. I'll post some pics later, whenever I figure out how to
do it.
Tony
« Last Edit: October 01, 2016, 10:10:57 PM by paw080 »
Offline Steve Lotz
« Reply #25 on: October 01, 2016, 04:18:18 AM »
It should be noted that Pat King's Jr. Rings use a much better(and fatter) airfoil so they might be "draggier" than the original. I would think they could use a higher powered engine.
Offline paw080
« Reply #26 on: October 01, 2016, 12:03:55 PM »
Yes Steve, I've built so many stock and modified Ring Jrs, I could see that Pat Kings design was no longer
a Ring Jr. The Pat King design does have a better airfoil, especially useful if the model will have a higher
wing loading than my 7oz modified Jrs.  If I'm allowed to reveal an old attitude; I think I really never
followed up with a larger wing area Ring Jr(to accommodate the Paw 1/2A and A diesel engines), because
I thought it would be easier to build an 8/12 oz Wee Duper Zilch and have a much better flying model
than the Ringmaster Jr design.  Yes, I used the same Cub .099 to power a WDZ in 1954.
Oh well; "These are the dry thoughts of a dry brain" (TS Elliot). ;D
Tony
Offline Steve Lotz
« Reply #27 on: October 01, 2016, 01:20:47 PM »
Wee Dupers look nice. Like a downsized Zilch X. I should build one someday. (thread drift)
