  • July 18, 2025, 12:13:34 AM
Author Topic: Buffing clear  (Read 1436 times)
Online James Mills
Buffing clear
« on: June 07, 2007, 08:31:38 PM »
What's the best material to use for buffing up Urethane clear?
James
AMA 491167
Re: Buffing clear
« Reply #1 on: June 07, 2007, 09:52:35 PM »
I like Phil Granderson's suggestion of using 3M rubbing compound then finishing compound followed by show glaze. But that's just me.
Re: Buffing clear
« Reply #2 on: June 08, 2007, 12:55:01 AM »
James,
I couldnt agree more with Phils comments via Randy,, I think that was in Model Aviation a couple months back. I have polished a few (hundred) cars with Urethane on them. Phil's article laid to rest some concerns I had about buffing on models. One comment, I dont remember if it was in the article, but your BEST optimal time to rub-a dub on that clear is usually between 24 hrs and 48 hours after shooting the clear. That is assuming 70 degrees, 50% humidity. Lots of patience and clean microfibre polishing clothes to wipe and inspect.
Re: Buffing clear
« Reply #3 on: June 08, 2007, 08:13:22 AM »
I think you're right Mark. The Slider was done some 6 months after finishing. Worked out OK, but it wasn't fun. The Novi was done 48 hours after shooting. Worked out better.
