  • July 22, 2025, 05:31:01 AM
Author Topic: Brodak Wildcat Almost the last flight!  (Read 1676 times)
Offline badbill
« on: November 22, 2015, 09:17:43 AM »
Me flying my buddy Dave Fountain's little TD .049 powered Brodak Wildcat yesterday, wringing it out. Almost wrecked it near the end of the video when the motor sputtered while I was overhead with it- didn't even have time to run backwards, I reached out and grabbed the up line and pulled . When I did, the motor caught and it came right out. Pure luck!
Bill Davenport
AMA 28141
Offline Dane Martin
  • heli pilot BHOR
Re: Brodak Wildcat Almost the last flight!
« Reply #1 on: November 22, 2015, 09:49:54 AM »
Great save. It got pretty wiggly there! Here's my third flight on my brand new RM95 ( video from last year). Engine shut off quickly from a bad run, right at a bad time... Lol
Flying the 95
« Reply #2 on: November 22, 2015, 12:03:14 PM »
 Nice save, but a bad reflex/instinct to develop. If that was a bigger plane with steel lines you'd likely have ended up with some sliced fingers. n1
 Thanks for the video, looks like a fun little plane. ;D
Offline badbill
« Reply #3 on: November 22, 2015, 12:28:04 PM »
It was steel lines  :'(
Bill Davenport
AMA 28141
« Reply #4 on: November 22, 2015, 01:21:36 PM »
    Indeed. The two ugliest accidents I have seen or heard of were not from prop cuts, but from the lines. If they slide across your skin with any sort of force, you are going to get sliced. One incident was essentially as described here, except with the infamous Skyray 35.
« Reply #5 on: November 22, 2015, 09:16:50 PM »
Yes, even 1/2A's can make for a trip to the emergency room if you grab the lines at a bad time.   The plane looks very capable for doing the pattern.
« Reply #6 on: November 22, 2015, 09:20:10 PM »
 Consider yourself lucky then. :)
Offline badbill
« Reply #7 on: November 23, 2015, 07:11:13 AM »
Buncha Killjoys! BUT, ya'll are right, I'll stop and think next time. BTW, that plane just flies awesome, the TD is on bladder pressure with a red cap and is quite the screamer.
Bill Davenport
AMA 28141
