  • June 21, 2025, 08:57:36 AM
Author Topic: Cox piston re set tool  (Read 1598 times)
Offline Bootlegger
« on: December 09, 2020, 09:29:12 AM »
  I have seen these, but now that I want one I can't find it..   It has a cup to put the piston in to use the reset tool.
  Where can I get one??   Obliged
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Peter Wakefield
Re: Cox piston re set tool
« Reply #1 on: December 09, 2020, 09:37:51 AM »
Offline Joe Ed Pederson
« Reply #2 on: December 09, 2020, 04:07:26 PM »
Boots,
Peter's lead is a good one, but there is another: http://www.exmodelengines.com/
I just checked exmodels and they have the reset tools for .010, and .049, but not the .020.  I recently needed the .020 reset tool and was able to get it from coxengines.ca
Joe Ed Pederson
Offline Bootlegger
« Reply #3 on: December 09, 2020, 04:44:33 PM »
   H^^  Sparky I knew that this forum would come thru and that is why I posted my question here, and they did and I got one headed to me now.  H^^   I am obliged, again... #^
Gil Causey
AMA# 6964
Offline Wayne Collier
« Reply #4 on: December 10, 2020, 03:41:17 AM »
I had a friend who re-set his ball joint. Put the tool in and lightly tapped as he slowly turned the tool around and around. Put the engine together and right after it started the top broke out of the piston because he work hardened it.
Set it up and give it a good shot with a hammer ONE TIME, then turn it 180 degrees and give it a smaller shot to close the cup where the slot in the tool was. If the ball joint feels stiff don't worry, it will loosen up as soon as the engine starts.
Motorman 8)
My method has been more like light tap - no difference. Light tap - no difference. Light tap - no difference. WHAP - a little snug. Somehow it’s worked out.
Actually I’m agreeing with Motorman.
Online Fredvon4
  • Central Texas
« Reply #5 on: December 10, 2020, 10:14:24 AM »
I’m too am agreeing with Motorman
Fred von Gortler IV
Offline Bootlegger
« Reply #6 on: December 10, 2020, 07:28:29 PM »
     H^^     Rootin' around the shop and BINGO found it !!!   Ain't life grand!!! D>K
Gil Causey
AMA# 6964
