  • July 11, 2025, 11:32:09 PM
Author Topic: ..Fillets gone bad...  (Read 1111 times)
Offline Bootlegger
« on: May 22, 2013, 08:31:45 AM »
  I put some fillets on a new model and they started to set up too quickly.
 What is the best way that you have found to sand them down, or remove them altogether?
  I am looking forward to finishing this model and need some insights/advice with this problem...
     Thanks a lot... y1
  Moderator if this need's to be moved please do so.
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: ..Fillets gone bad...
« Reply #1 on: May 22, 2013, 10:01:02 AM »
What is the material?
Heat works with resins and some chemicals work with other materials.
Charles
« Reply #2 on: May 22, 2013, 01:24:47 PM »
I know stripper will loosen SuperFil fillets. Paint it on there and the fillets will let go.
Offline Bootlegger
« Reply #3 on: May 23, 2013, 03:59:47 PM »
  Thanks guy's, I think that I might grind them down, and cover them with leather fillets.
 Will try to keep you updated as to what I do and how it works.
  Again THANKS... #^
Gil Causey
AMA# 6964
Offline Mike Lauerman
« Reply #4 on: May 23, 2013, 05:54:28 PM »
Leather fillets saved the day for me on a 'wing root gone bad'. Bill Sawyer (RIP) sent me out some sets in assorted sizes, I had forgotten how handy these were in the 'old days'!
