At Brodak, I got a Cobra short kit. After a couple of days, I have a completed stab and elevator assembly minus the horn, and tapered the rudder. I don't speed build like sparky, and I'm still learning, but I am a lot better than I was when I built the Ares, I can tell you that.
We are going to try something different when I build the wing. I'm going to make two more templates for where the wing root would be, and then build the wing outside the body, then put the wing into the fuselage.
Later today I'm going to laminate the doublers onto the fuselage sides. I plan on putting an OS 35S in this plane.
The Oriental Plus project has been suspended until I get a motor for it (PA 40UL), so for the time being, I'll start working on the cobra
