  • July 05, 2025, 10:39:52 PM
Author Topic: blank  (Read 1327 times)
Online Motorman
blank
« on: August 23, 2013, 11:22:05 AM »
blank
« Last Edit: September 10, 2021, 07:51:16 AM by Motorman »
Re: Brodak Profile Tanager (Bellcrank)
« Reply #1 on: August 23, 2013, 11:49:48 AM »
Hi Walt,
If you are actually getting 20* and 30* then I would say that hole is the one to use.  You may never use the full throws, but then in panic mode it would be there......
BIG Bear
RNMM/AMM
Offline Allen Eshleman
« Reply #2 on: August 23, 2013, 09:03:32 PM »
What engine do you have on the Tanager?
« Reply #3 on: August 24, 2013, 09:00:00 AM »
Your wrist movement and the handle spacing  to me decides how much bell crank movement you get when flying a CL plane.   I too try to get as much bell crank movement as I can.   That means that some times the middle hole is too far from the pivot point.  I had a Dolphin that the flaps/elevators were max 25 degrees and was too quick for me.   Balance has a lot to do with it also.
« Reply #4 on: August 24, 2013, 05:24:41 PM »
How long is the flap horn? That determines where you attach the BC/flap pushrod (top hole). The BC attachment point should be shorter than the top hole on the flap horn, never longer.  H^^ Steve
« Reply #5 on: August 24, 2013, 09:22:39 PM »
Use a wider handle spacing! Sounds good to me, 'cause the wider the handle spacing, in theory, your precision improves.  If you are using a "TED handle", you can reverse the stainless steel legs to widen the spacing.  #^ Steve
