  • June 19, 2025, 11:48:31 AM
Author Topic: Brodak Pathfinder  (Read 2540 times)
Offline rich gorrill
Brodak Pathfinder
« on: October 12, 2017, 02:17:44 PM »
Hello all, does anyone know if the Pathfinder has a solid 1/2" fuselage or is it built up like the Cardinal? Anyone flying a Pathfinder comments  please either pro or con.
t.i.a.
Rich
Offline peabody
Re: Brodak Pathfinder
« Reply #1 on: October 12, 2017, 05:59:34 PM »
Pathfinders are terrific flying profiles...
The fuse does tend to flex because of the size of te tail....most have reinforced the fuselage with glass or carbon fiber mat on their second version.
It can also be build as a taildragger by inventing a tailwheeL and reversing the landing gear legs....
I suggest a 46 (or an ST 51) as power.
Have fun!
Offline Gerald Arana
« Reply #2 on: October 12, 2017, 07:35:28 PM »
t.i.a.
Rich
Yes, I built one with a Jett BSE 40. It has/had a solid 1/2" fuse. I never noticed it flexing, but then again that was when I flew intermediate. I crashed it when I couldn't decide which way to pull out of the W.O. Duh!
Cheers, Jerry
OBTW: It had plenty of power!
Offline Norm Furutani
« Reply #3 on: October 13, 2017, 02:56:02 AM »
My Brodak ARF Pathfinder has a built up profile fuselage. It is completely skinned in balsa, but the rear section is hollow. The fuse does flex but doesn't seem to affect performance.
Norm
« Reply #4 on: October 13, 2017, 09:25:23 AM »
thanks for the replies
Offline Perry Rose
« Reply #5 on: October 13, 2017, 04:18:06 PM »
Somewhere in here is Gordon Delany's recommendation for improving the Pathfinder profile. I scratch built one like he said and it flys a lot better than the kit version.
Offline Brent Williams
« Reply #6 on: October 13, 2017, 04:43:23 PM »
Gordan's usual build tips/mods are:
1.  Set the hinge to hinge measurement at 16" (this may require cutting a bit off of the end of the supplied Brodak fuselage)
2.  Build the stab and elevator from 3/8" material.
3.  Sand a mild taper into the tips of the stab and elevator
4.  Keep it light.
5.  Build it straight.
Also, I would recommend that you laminate two 4x36 x 1/4" pieces using 30min epoxy for the fuselage.  Much stiffer than a single 1/2" plank.
« Last Edit: October 14, 2017, 02:23:26 AM by Brent Williams »
Offline Gordan Delaney
« Reply #7 on: October 16, 2017, 09:37:03 AM »
Brent has most of the changes right except one.
I only use 3/8 stab on my .15 twin.
I use 1/2 in stab and taper it to the tips, and sharpen the leading edge more than the plans show.
Gordan Delaney
