General control line discussion => Open Forum => Topic started by: cory colquhoun on September 06, 2017, 04:31:23 AM
Can anyone tell me if it's possible to buy directly off brodak to Aus or do you have to go through one of their outlets ? I've sent emails asking ,with no reply, thanks cory
Best you call 724-966-2726. That will put you in touch with someone who can answer your questions. They ship all over but I don't know the specifics you may need.
Wayne
It is possible Corey, but it ain't cheap - there are two problems: 1) the Aussie dollar is not real flash against the US dollar currently and 2) postage costs are somewhat prohibitive, especially if you wish to purchase either large or heavy components.
My past dealings direct with Brodak when the dollar was at parity were all pleasant experiences, good communications and prompt delivery.
If we knew what you were specifically after, I guess more information could be provided.
Cheers, Tony.
Cory - Call Jan at 724 966 5975.
Tell her I recommended that you speak with her.
As Tony asks, what do you need specifically? Maybe we can help. D>K
Was chasing a set of cardinal plans , thanks guys
I would try to go digital on a set of plans, just send through email.
MM
Oh,that sounds good will give it a try, thanks cory
For just a plan I'd not expect the postage to be excessive.
http://brodak.com/cardinal-plan.html
No worries ,just wasn't sure as they have a "where to buy" at top of their page
I've ordered many times from the website. From kits to small hardware orders. Post isn't too bad. Like you I have the same problem with the exchange rate. Kiwi is about the same as the Aussie.
Cory:
Call or e mail them and ask that the plans be folded instead of rolled. That way the plans can be placed into an envelope and mailed to AUS by International Frist Class Mail. That method is much less expensive. RSM has never had any problems with shipments to AUS using the Post Office.
Cory:
Set of plans on its way as well as some bits and pieces, postage wasn't to bad , thanks for the tip
Cory
