  • July 27, 2025, 06:11:02 PM
Author Topic: Prop Question  (Read 1231 times)
Offline Leester
Prop Question
« on: September 02, 2006, 07:25:53 PM »
I was flying my ARF Oriental tonight, it has an L&J Fox 35 using 10/28 fuel on 60' eye to eye lines .015. The first flight I was using a MAS 10-6 it needed a touch more speed and line pull. I changed to a BY&O 10-6, line pull was better but still needed a touch more speed. The engine RPM's where right on since it would break as soon as I nosed up. Will a APC 10-6 make a difference? or what prop should I try next? Unless I've got it wrong you adjust speed by props right?   Thanks.
Leester
ama 830538
Re: Prop Question
« Reply #1 on: September 02, 2006, 07:38:08 PM »
You are correct.  You adjust the airspeed of the plane with the prop.  Adjust lap times with the line length.  Adjust engine run with the NVA, and other "engine" methods.
A B-Y&O 10-6 is probably closer to a 5 or less pitch on a Prather gague.  They tend to come out on the weak side in pitch.  Plus a wood prop can change from the time is was blanked out and finished until it cured.
APCs tend to be good for advertised pitch.  I don't like the weight of the APCs on a Fox, but a lot of people use them.
Go with the APC.
Bill <><
Offline John Paris
Re: Prop Question
« Reply #2 on: September 02, 2006, 07:47:08 PM »
Leester,
I use APC 10x5 on all of my stunt airplanes that have a Fox 35 on them.  For reference, the stock engines like about 10K for launch speeds, but the one L&J that I have worked with prefered 10.6K if I remember right.  Also, I use 63 feet of .015" on my Oriental with a SilverFoxx.  At less than 3 bucks, it is a cheap experiment.
John Paris
269
Offline Leester
Re: Prop Question
« Reply #3 on: September 02, 2006, 08:16:04 PM »
Bill and John: Thanks I've got both the 10-5 and 10-6 in APC so I'll give them a try, I've also got a TT 10-5.5 one of them should do it.   j1 j1 j1 f~
Leester
ama 830538
