I got the following message from Doug Galbreath:
LArry
I notice you were on the Stuka Stunt forum..
In regards to the Nelson head I make and the plug too tight problem. This is the fault of the plugs, not the head. If you would mention this on the stunt forum I would appreciate it. If they would send me the offending plugs I will fix them. I have had to do over 500 of them recently. About one or two out of every 6 is OK,
Plug bodies are made on a multi spindle screw machine. One or more of the spindles seems to have a bad bearing. I did not notice this problem when it first appeared, but I have been re-threading them ever since.
Thand for Doing this for me.
Doug Galbreath
