  • June 16, 2025, 11:46:03 PM
Author Topic: Cloth Hinges  (Read 2481 times)
Offline Zuriel Armstrong
Cloth Hinges
« on: June 13, 2006, 12:18:36 PM »
Last night I installed the flaps on my new plane and used Tom Morris' dacron hinges.  It was really pretty easy to do and I liked the results.  The plane has 585 sq/in wing and will use an LA 46 for power.  Why are these hinges not used more often?  Does it not look modern enough or is their some issue with them that makes the undesirable.  Also is there a size or motor limit using cloth hinges?
Zuriel Armstrong
AMA 20932
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Cloth Hinges
« Reply #1 on: June 13, 2006, 01:15:57 PM »
Only reason I don't use cloth is I like to finish the flaps and elevators off the airplane. Except for that I believe there are good reasons to use cloth.
Re: Cloth Hinges
« Reply #2 on: June 13, 2006, 01:45:41 PM »
Howdy Ty,
The wing is not installed yet and I used thinned dope to adhere the hinges.  They will almost disappear when covered.  I thought it was just too easy.
Hey Bob,
Are you coming to Dallas this weekend?  I hope to see you there.
Zuriel Armstrong
AMA 20932
Re: Cloth Hinges
« Reply #3 on: June 13, 2006, 02:22:43 PM »
Zuriel,
Get-er-dunn!!!! f~
Post some pictures if you get a chance. I know you are pressed for time.
Offline Bob Reeves
Re: Cloth Hinges
« Reply #4 on: June 13, 2006, 03:00:15 PM »
Hey Bob,
Apreciate the thought but have allot of things going on in my life right now and am lucky to be able to get to the Tulsa field.. Hoping all this will be over by next season and I can get back in the grove.. The rust is showing with the last two years taking it's toll on my flying time but I'll be back  ;D
Re: Cloth Hinges
« Reply #5 on: June 13, 2006, 10:09:03 PM »
Actually a certain World Champion has used them on 60 piped planes.  No reason not to.
The flaps can still be installed after the wing in glued in.  Many people do not cover the wing before they install it.  Anyways, an I-beam airplane's wing can't be covered before the wing is installed if you buid it in the traditional manner.
I love 'em and use them all the time.
Offline Mike Clark
  • Lets get together and burn some fuel!
  • ACE
Re: Cloth Hinges
« Reply #6 on: June 15, 2006, 09:41:26 AM »
Hi Guys,
I use both!
All my classic ships sport the dacron hinge method and most of my modern stunt ships use klett hinges. It's not a question of ability, no both systems are more than adquite for the task at hand, if installed properly!
The newer stunt ship wings wll have more of a clean cut look with the diamond edge of the flap leading edge connect to the wings trailing edge, with hinges.
Most of my classic ships that I fly have nice rounded edges.  That lends itself to rounded trailing edges on the wing and flaps which is what is needed for the application of dacron hinges. I guess it's more of a LOOK thang than anything else.
Mike Clark
Mike Clark
