  • July 02, 2025, 05:35:23 PM
Author Topic: Brodak dope  (Read 2676 times)
Offline Greg Hart
Brodak dope
« on: February 20, 2014, 02:09:10 PM »
Is the colored dope fuel proof? I know clear is but is the colored dope as fuel proof as the clear?
BUY A UKEY AND LEARN
Joe Just
Re: Brodak dope
« Reply #1 on: February 20, 2014, 02:21:26 PM »
Greg, It works for me quite well. However I do not use any fuel above 10% on my Carrier stuff.
Joe
PS How are you enjoying the DVD's?
Offline Balsa Butcher
  • High Desert Flier
Re: Brodak dope
« Reply #2 on: February 20, 2014, 11:54:26 PM »
Brodak color is fuel resistant but not as fuel resistant as their clear. Best policy is to spray a few coats (at least) over the color. Otherwise raw or hot fuel will eventually discolor the finish creating "nitro stripes".                       Not a good thing. :(
Pete Cunha
Sacramento CA.
AMA 57499
Offline johnt4051
    • Flying Lines
Re: Brodak dope
« Reply #3 on: February 21, 2014, 12:07:04 PM »
From experience and also from conversation with John Brodak: The color dope is definitely not  n1 fuelproof.  The clear is fuelproof for low nitro if you put enough on.  By that I mean, lots.
--jt
John Thompson
Flying Lines
  • High Desert Flier
Re: Brodak dope
« Reply #4 on: February 21, 2014, 12:57:02 PM »
Good to know, I stand corrected. That explains a lot. Also, don't do what I have done: Put on multiple coats of clear then sand/polish through it and back into the color. Great shine at first but doesn't last. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Re: Brodak dope
« Reply #5 on: February 21, 2014, 05:58:40 PM »
Look closely at the airplane in the photo.  My GeoXL getting ready for flight with Bart K. holding.
The paint missing beneath the tank area happened the first time I filled the tank.  Fuel Proof...NOT!  Brodak Dope.  If you use this stuff, and I have a lot of it, make sure you cover it with 2 part automotive clear!  It simply turns to liquid with raw fuel and runs off on the ground.
  • High Desert Flier
Re: Brodak dope
« Reply #6 on: February 21, 2014, 06:52:13 PM »
Holy Cow Randy, what type of fuel do you run in that plane...25% Nitro? Looks pretty bad, nice picture though. It may even get a few more NE fliers to consider moving out of the snow belt and into the sun belt. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Re: Brodak dope
« Reply #7 on: February 21, 2014, 07:48:36 PM »
OK...are you ready...That's a Belko long shaft .56 and runs only on NO NITRO Fuel!  Methanol and oil only!  The Methanol alone will do it!
I wondered if anyone would pick up on this!
Re: Brodak dope
« Reply #8 on: February 22, 2014, 12:50:47 AM »
That picture was taken about 3 years ago in January at the Southwest CL Regional Champ's.
About 75 degrees.  C'mon down...no place better for CL Stunt.
Re: Brodak dope
« Reply #9 on: February 22, 2014, 01:11:54 AM »
Damn Randy, you look younger than me, and I'm 57! Good going. H^^
Rusty
