  • July 18, 2025, 09:57:30 AM
Author Topic: "Reply" window with a mind of it's own?  (Read 798 times)
« on: December 02, 2011, 11:18:55 AM »
Why does the reply window jump around? Well, that is, when you reach a certain number of lines.  ;D
I'm sure there's a good reason.
CB
Offline Serge_Krauss
Re: "Reply" window with a mind of it's own?
« Reply #1 on: December 02, 2011, 11:56:50 AM »
Several of us have had this problem, and a search would turn up the solution. I believe it is to click on "tools" and then on "compatability view". 'hope I'm not wrong, but try it.
SK
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #2 on: December 02, 2011, 06:27:28 PM »
I think it has to do with your display width. Some posts have very wide links or graphics, for instance - on larger displays, there's no jumping around as you scroll through them. But on smaller displays, the wide image forces a horizontal scroll (left or right?), and when you're back to a narrow post, the display settles back down.
The solution is obvious - that new Apple computer with the 30" wide flatscreen display (plus perhaps 2 more screens of the same size). ;->
L.
"You may be disappointed if you fail, but you are doomed if you don't try." -Beverly Sills
