  • July 10, 2025, 11:55:17 AM
Author Topic: Brodak 40 measurements  (Read 1367 times)
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
« on: February 25, 2007, 06:29:19 AM »
I'm waiting for a Brodak 40 to arrive for my Cardinal, so work has been temporarily halted on the fuselage.
Does anyone have the dimensions of Brodak 40?  I know it's supposed to be the same footprint as an OS FP40/LA40 but do the holes line up? And what's the length from front to rear, it looks shorter which means you would NOT be able to swap between OS and Brodak engines.
You would think Brodak would have this kind of info on the website?
Cheers
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Leester
Re: Brodak 40 measurements
« Reply #1 on: February 25, 2007, 06:45:20 AM »
Hi Warren: Here goes, from the spinner back plate to the end of the back plate screws is 2 11/16 ". Engine width for motor mounts 1 1/4", depth from motor mounts down to back plate bottum screw 13/16".engine mounts are side to side 1 9/16" front to back 11/16" center to center. Hope these are accurate enough.
Leester
ama 830538
  • AUS-14782
    • My Home Page
« Reply #2 on: February 25, 2007, 07:12:52 AM »
Thanks Leester
So The B40 is about 1/4" shorter than the LA40/46 - everything else is about the same.
Warren Leadbeatter
AUS-14782
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: February 25, 2007, 07:49:05 AM »
It is a drop in replacement for the MAX 35S, if you have a 35s you can use it to locate your holes and spinner. The only difference is the needle valve location is a tad off.
  • AUS-14782
    • My Home Page
« Reply #4 on: February 26, 2007, 12:59:43 AM »
Hi Bob
No I don't have a MAX 35S. I'll just have to wait. Shouldn't be too long now...
Cheers
Warren Leadbeatter
AUS-14782
  • AUS-14782
    • My Home Page
« Reply #5 on: March 01, 2007, 03:56:42 AM »
John Brodak sent me a pic of the engine in actual size, so I've decided the world needs to know the definitive answer.    n~
A = 40.5mm (1 5/8")
B = 17.5mm (11/16")
C = 69.5mm (2 3/4")
D = 48.6mm (1 15/16")
E = 85.3mm (3 3/8")
F = 47mm (1 7/8")
G = 31mm (1 1/4")
H = 38.2mm (1 1/2")
J = 65.55mm (2 9/16")
« Last Edit: March 01, 2007, 05:44:38 AM by Warren Leadbeatter »
Warren Leadbeatter
AUS-14782
