  • July 17, 2025, 10:33:43 PM
Author Topic: Brodak .40 chip muffler anyone  (Read 2418 times)
« on: January 22, 2017, 05:47:58 PM »
So I'm trying to get my 1976 Nats Moby Dick back in the air for VSC Super '70s.  As there was an obvious reasonn for the name "Moby Dick" I wanted a bit more oomph for the altlitude and heat in Tucson.  A Brodak .40 fits like a glove in the original OS 35S mounts and only extends the spinner about 3/16" which is in the acceptable noise range for such a project.  Only downside I've found is that with the original muffler the CG is a little forward of where I would like it...plus, it's not the prettiest looking critter hanging out the side.
Can anyone recommend a high quality Chip Muffler for the B.40 from one of our garage outfitters?
Ted
Offline tom brightbill
Re: Brodak .40 chip muffler anyone
« Reply #1 on: January 22, 2017, 06:18:54 PM »
Scott Riese makes beautiful polished ones. His contact info is in the members list.
AMA 34849
« Reply #2 on: January 22, 2017, 06:25:07 PM »
Polish up a muffler from Eric at RSM.  I have one permanently JB Welded to my Brodak 40.  With the ball socket wrench I use don't have to remove muffler to install or remove the 40.
« Reply #3 on: January 22, 2017, 06:36:03 PM »
Pete Peterson has a collection and I can make one easily enough.
Online Jim Hoffman
« Reply #4 on: January 22, 2017, 07:11:32 PM »
Eric's tongue muffler has been the best choice on my two OTS planes w/ Brodak 40s
Jim Hoffman
Online Motorman
« Reply #5 on: January 22, 2017, 09:20:28 PM »
blank
« Last Edit: March 06, 2022, 04:11:59 PM by Motorman »
Offline kenneth cook
« Reply #6 on: January 23, 2017, 03:01:52 AM »
               Randy Smith's tongue muffler works great. You can also alter the holes if needed by drilling them out to the next size. The RSM version has very small holes in which you really can't open up a whole lot without breaking into the next hole. Your alternative is to either make another row or use the existing as a drill guide and go out the opposing side.
« Reply #7 on: January 23, 2017, 11:47:27 PM »
Thanks guys.  I've ordered one from Eric and should get it in a day or two.
Ted
Offline John Lindberg
« Reply #8 on: January 24, 2017, 07:06:28 AM »
The Du-Bro line of spinners cover up the open space between the nose and backplate more than others, you probably already know that, they are pretty sturdy!  D>K
Offline Scott B. Riese
  • Just a student of stunt
« Reply #9 on: January 26, 2017, 07:35:14 PM »
Ted
ted.......we can do it
Scott Riese
Portland, Oregon
AMA 528301
