  • June 15, 2025, 09:31:48 AM
Author Topic: Caster oil addition  (Read 740 times)
Offline Lyle Spiegel
Caster oil addition
« on: June 07, 2020, 01:08:15 PM »
I have full gallon RC fuel with 18% total oil. Want to boost oil to 22% to match Powermaster 10-22. How much more caster do I need to add? Thx
Lyle Spiegel AMA 19775
Offline Richard Imhoff
Re: Caster oil addition
« Reply #1 on: June 07, 2020, 01:14:26 PM »
http://nitrorc.com/fuelws/
The PLACE you want.
Dick Imhoff  AMA 58502
Combat, Racing, Stunt, and big time fun flyer, and Maybe a bit of carrier.
Online frank williams
« Reply #2 on: June 07, 2020, 01:33:28 PM »
Add 6.5 oz of castor to the full gallon to get a total of 22% oil.  Nitro content will be reduced to 9.5%.
Offline Pat Chewning
« Reply #3 on: June 09, 2020, 09:40:05 PM »
The calculator says to add 6.2 oz .    You will end up with 22% oil and 9.5% Nitro
Offline Ara Dedekian
  • Ara Dedekian
« Reply #4 on: June 11, 2020, 02:47:52 PM »
       Hi Lyle
           As a brain dead guy on even arithmetic, I could get hung out to dry by the mathamaticians on here. But as a general rule, one ounce of castor to a gallon raises the oil content one percent by volume. The results seem to be close enough.
      Ara
Online Trostle
« Reply #5 on: June 11, 2020, 03:31:43 PM »
       Hi Lyle
      Ara
Not trying to be picky, but adding one ounce of castor to one gallon of fuel increases the oil content by 0.78%.  May work if that is the only increase desired.  However, if adding "several" more ounces of castor to get "several" percentage points in oil content, that "close enough" approach may not get the results desired.  For example, adding 4 ounces of castor will increase the oil content 3.1%.  That is good if that is what is desired.  It helps to know what you are doing.
« Reply #6 on: June 11, 2020, 04:15:03 PM »
How about if we start yet another argument on whether to measure by weight or by volume!
(Let's not)
I do it the hard way.  Calculate percentages of each component, by weight.  Knowing the existing weight AND percentage oil in the original mix, add enough oil to increase weight of total oil to desired number.
The resultant total volume (weight) will be greater than original, throwing the numbers off by "a bit".  i DON'T SWEAT THE SMALL STUFF.
Re: Castor oil addition
« Reply #7 on: June 16, 2020, 05:49:33 PM »
Adding 6 or 8 oz. of castor oil would be fine.  y1 Steve
