  • July 20, 2025, 10:15:05 PM
Author Topic: Brodak .40  (Read 3074 times)
Offline Brian Massey
    • California Car Clubs
Brodak .40
« on: October 08, 2009, 01:39:07 PM »
I just received a nib Brodak .40 I purchased from a private party and couldn't be happier  y1 .  The motor looks beautiful, and seems to be beautifully made; it backed up the looks with easy starts and strong running.
Thinking I would like another, I looked on the Brodak site hoping to find out when they will have them back in stock, but they have been dropped from the website. Anyone know what's going on?
Brian
AMA 55421
Madera, CA
Offline Matt Colan
Re: Brodak .40
« Reply #1 on: October 08, 2009, 01:43:11 PM »
They have been on back order and not for sale forever.  From what I've heard, the guy who was making the engines, somewhere in Europe (Slovakia I think) didn't want to make them anymore.  That's what I heard but not sure.
Best thing to do is wait until somebody decides to sell one and the nsnatch it up.
Offline Leester
Re: Brodak .40
« Reply #2 on: October 08, 2009, 01:44:46 PM »
Better check the web site again, it's there.
Leester
ama 830538
Offline Wayne J. Buran
Re: Brodak .40
« Reply #3 on: October 08, 2009, 01:52:18 PM »
The .25 is the .40 isnt.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Re: Brodak .40
« Reply #4 on: October 08, 2009, 01:52:49 PM »
Yep, it's there. That was the darehobby web lisitng of Brodak engines that it's no longer listed on.
Brian
AMA 55421
Madera, CA
Offline Leester
Re: Brodak .40
« Reply #5 on: October 08, 2009, 02:10:30 PM »
Wayne I was talking about the listing being there, not the availability.
Leester
ama 830538
Re: Brodak .40
« Reply #6 on: October 08, 2009, 02:22:12 PM »
I've got about 15 2 minute runs on the Brodak .40; all without the muffler per the instructions. So now I pick up the muffler and see it has no nipple for muffler pressure, nor is it tapped for one. I thought I would drill and tap it myself, but the muffler is very thin wall material.
Are most Brodak .40 owners running without muffler pressure?
Does the engine runs better with muffler pressure?
Is the muffler too thin to tap?
Brian
AMA 55421
Madera, CA
Offline Leester
Re: Brodak .40
« Reply #7 on: October 08, 2009, 02:26:11 PM »
The 2 I'm running run great and are not taped for pressure.
Leester
ama 830538
Offline Matt Colan
Re: Brodak .40
« Reply #8 on: October 08, 2009, 02:41:51 PM »
I'm running pressure, that muffler is a pretty quite one too.
Alan Hahn
Re: Brodak .40
« Reply #9 on: October 08, 2009, 03:06:12 PM »
Brian
I have never felt a need for pressure with my two B40's.
Offline Peter Hess
Re: Brodak .40
« Reply #10 on: October 08, 2009, 03:31:30 PM »
Neither of mine uses or shows any need for muffler pressure.
Peter Hess
Canton, CT
AMA 485070
Re: Brodak .40
« Reply #11 on: October 08, 2009, 05:01:36 PM »
Thanks for all the resonses; sounds like I don't need muffler pressure, so that will be my starting point.
Brian
AMA 55421
Madera, CA
Alan Hahn
Re: Brodak .40
« Reply #12 on: October 08, 2009, 05:59:06 PM »
Brian,
Just to be clear, I don't use muffler pressure because at least in CL with the venturi's I use, I haven't found it necessary.
That doesn't mean that it doesn't work. I think the motivation in RC was to help offset the pressure drop the RC engine carb sees as the standard tank empties---that was back in the days when RC planes mainly flew in horizontal paths with the wings nominally level (even if inverted)!  S?P
Also in the attempt to get as much power ( at high rpm's) in the RC setup, the carb was often pretty big at wot, and the fuel draw as a result was poor. Muffler pressure helps in that case.
As you have noticed, our venturi's are pretty small by comparison with the RC carb--at least most RC engines.
So if you want to try pressure, go ahead, it may work well for you.
Offline Phil Spillman
Re: Brodak .40
« Reply #13 on: October 08, 2009, 07:16:57 PM »
Muffler pressure in general is like brasiers some use um and some don't! As for my preferences I use it and feel .....uplifted and secure...others don't...feel the need and just leave um flapping! I'd rather be firm in my fuel draw in ALL attitudes..muffler pressure...lifts me up and holds my fuel flow even and strong!!!!!!!!!!!!! Phil Spillman
Phil Spillman
Re: Brodak .40
« Reply #14 on: October 08, 2009, 07:57:27 PM »
Phil:
words    fail     me     b1    :o   H^^     LL~    LL~   LL~
Offline Richard Grogan
Re: Brodak .40
« Reply #15 on: October 08, 2009, 09:21:34 PM »
Sounds like Phil has already lifted and separated!  LL~
Long Live the CL Crowd!
                  AMA 85745
Offline Bill Ervin
Re: Brodak .40
« Reply #16 on: October 08, 2009, 09:32:59 PM »
So Phil since you are obviously enjoying muffler pressure (maybe a little too much).  Where exactly did you...ummm...locate the nipple?
« Last Edit: October 08, 2009, 10:44:21 PM by Bill Ervin »
Offline Balsa Butcher
  • High Desert Flier
Re: Brodak .40
« Reply #17 on: October 08, 2009, 09:43:47 PM »
Well, the B-40 is one of my favorite engines and one of few that I use muffler pressure on. I install the pressure fitting on the muffler "stalk", between the can and the mounting flange. As the muffler can is not centered I like to put it on the bottom so that if the engine is mounted inverted the fitting will be facing upward.
If you are mounting it on a cowled ship drill it close to the can so that it does not interfere with cowl fit. As stated, some's like pressure, some's don't, I try both and let the engine decide. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline David Shad
Re: Brodak .40
« Reply #18 on: October 09, 2009, 09:26:28 AM »
I have several B-40's and have tried pressure and without.  They are very easy engines and ran great
both ways.  I have two on an RSM LA Heat...tongue mufflers and pressure.  One on my Smoothie with
a tongue muffler without pressure on uniflow...great run...ask Bob Zambelli...he launched me at KOI this
year and was amazed at the consistant run everytime.
Big Dave AMA 80235
Offline Robert Zambelli
Re: Brodak .40
« Reply #19 on: October 09, 2009, 12:54:41 PM »
I still have Brodak 40 #1, the very first one, belonging to John Brodak.
It's been on many planes including the first ARF (Cardinal) and now rests on the prototype ARC Smoothie.
It has been run on a wide variety of props, tanks and fuels and seems to behave well on most.
To this day, it runs flawlessly and the Brodak 40 is, in my opinion, the best all-around stunt/sport engine ever made.
A few people swear that it has to be reworked to give a decent run. Doing so will accomplish one sure thing - a voided warranty.
I recently spoke to John and he informed me that a new group should be here in the near future but they are mostly if not all spoken for. Also, there is a waiting list.
The best way to get information regarding delivery/schedule is to call Brodaks directly.
Re: Brodak .40
« Reply #20 on: October 09, 2009, 01:26:46 PM »
I remember the first B-40 I had seen or heard.  the young fellow was having nothing but trouble with it.  Could not get needle settings and would quithalf way thru the tank most of the time.  I inquired if it was broken in and was told it  didn't need breaking in.  I turned around and got my plane ready to go.  I also have several of the B-25's and they are just as dependable.  DOC Holliday
Offline Matt Colan
Re: Brodak .40
« Reply #21 on: October 09, 2009, 02:35:46 PM »
The Brodak 40 I have in my Smoothie ARC does run flawlessly, I  really don't know how people have been having trouble with this motor.  Our motor has been crashed twice, and just got a new needle valve and that thing just runs the same run after run after run.  You do need one flight to set the needle and that is it.
Alan Hahn
Re: Brodak .40
« Reply #22 on: October 09, 2009, 04:28:13 PM »
I have two (as I said) that run great.
However I will believe that any industrial produced product will have a few that just don't work right, so my belief is that those who have issues generally have one of the outliers  :'( --and are not necessarily incompetent (but of course their are a few outliers  n~ in the user category too!)
Re: Brodak .40
« Reply #23 on: October 09, 2009, 05:01:26 PM »
I have a B40 on my flapped 526 Ringmaster, which Pat Johnston designed specifically for that motor, and has run consistently from the first flip. A perfect combo and very dependable.
                  AMA 85745
