  • June 29, 2025, 04:36:00 AM
Author Topic: Your least favorite maneuver  (Read 1688 times)
Offline Matt Colan
« on: June 03, 2009, 07:07:16 AM »
Well, we heard what your favorite maneuver is, and what maneuver that could be added to the pattern, how about your least favorite maneuver or your worst maneuver?  Me, I never fancied the square 8s or the 4-leaf.
Offline Larrys4227
Re: Your least favorite maneuver
« Reply #1 on: June 03, 2009, 07:24:30 AM »
Anything that is directly overhead.  I've got a bad neck/shoulder and its hard to look straight up.  I attempted an overhead-8 once... lost the plane from sight but luckily came back into view on the side I was facing. :-)
FlySafe!  Larry (Larrys4227)
« Reply #2 on: June 03, 2009, 09:28:22 AM »
The take off.   Always get up tight on landings.  DOC Holliday LL~ LL~ LL~ LL~
Offline James C. Johnson
« Reply #3 on: June 03, 2009, 11:23:32 AM »
Square 8s..
Jim
Offline catdaddy
  • catdaddy
  • The Dude Abides
    • Tulsa Gluedobber Control Line Club
« Reply #4 on: June 03, 2009, 02:29:10 PM »
Hourglass, no question.
regards,
Rick"catdaddy"Blankenship
Offline Phil Coopy
« Reply #5 on: June 03, 2009, 02:31:03 PM »
The @#$% hourglass.. HB~>
Phil
Offline Bill Heher
  • Fix-it
« Reply #6 on: June 03, 2009, 03:26:13 PM »
Panic Pull Out from inverted flight using up  - into the ground,  I practiced it again today-sheesh I hate that!
Bill Heher
If it's broke Fix-it
« Reply #7 on: June 03, 2009, 03:42:29 PM »
The last manuever of a flight,, unless its the landing, that one is ok,, but when its the outside squares,, or the square 8,, it really bites when thats the last manuever,,  ???
Offline Richard Grogan
« Reply #8 on: June 03, 2009, 04:16:29 PM »
The exit of a figure 9. Its a killer  :X
Long Live the CL Crowd!
                  AMA 85745
Offline Clayton Berry
  • Grey haired kid to be wary of
« Reply #9 on: June 03, 2009, 09:28:11 PM »
Perhaps outside squares.
The plane is flying at full speed, and you head it directly to the ground.  And pull out with lots of down elevator.  I know everything is going to work, but it still gives me the heebeegeebees.  The second one is perhaps eaiser because the plane has slowed down a bit - but, do you try to keep it in the same path to be consistent?  Or do you do one like it should have been done a few seconds earlier?
Judges:  Hey, he was a bit low, but he did it twice!
Judges:  What a lousy couple of loops.
Judges:  Wow.  Hard four corners, and just the right size.  Did you notice how his watch quivers at exactly 89.7 cycles per second?
Hey, judges don't talk to each other.
Clayton - forever busy committing random acts of coolness
Offline Jim Pollock
« Reply #10 on: June 04, 2009, 04:48:33 AM »
Ummmmm,
Lets see now......I think the maneuver I hate most is overhead eights  - when your looking up just where exactly is that blessed vertical 90 degree line you so desperately need to fly that silly maneuver anyway!!!!  Answer: NOWHERE!
Jim Pollock  ~>
Offline Bill Hodges
« Reply #11 on: June 04, 2009, 05:48:26 AM »
The hourglass.  I can never get it right.
Bill Hodges
Bill Hodges
AMA 12450
