  • June 24, 2025, 02:14:08 PM
Author Topic: dessicant hose...  (Read 1629 times)
Offline Bootlegger
dessicant hose...
« on: March 30, 2009, 12:08:47 PM »
    #^       Guy's seem's that I read here on the hanger that someone had a dessicant hose that they used to trap excess water , now I can't find the info. I thought that it was at this address tcbglobal.
  Couldn't find it...
  Any help sure will be appreciated... H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bootlegger
Re: dessicant hose...
« Reply #1 on: March 31, 2009, 09:59:14 AM »
   Thanks Ty, I'll look into those.. Thanks again.... H^^
Gil Causey
AMA# 6964
Offline Bill Heher
  • Fix-it
« Reply #2 on: March 31, 2009, 11:23:58 AM »
Harbor Freight also sells a combo Regulator / oiler / water trap that you can put on you air hose. It is usually on sale for $20. Leave the oiler dry and you have a regulator / water trap for spraying.
Bill Heher
If it's broke Fix-it
Offline Pinecone
« Reply #3 on: April 09, 2009, 12:04:38 PM »
Here it is:
http://www.tcpglobal.com/spraygundepot/itemdetail.aspx?itemno=DEV+130502
The filter traps only remove water droplets.  This reduces the water content down to a very low level.  They also make wall mount systems with replaceable dessicant.
IIRC dessicants can get down to dew points of like -30.
Terry Carraway
AMA 47402
Offline Bootlegger
« Reply #4 on: April 10, 2009, 06:01:45 AM »
  Guy's I appreciate all the help with this.             #^
Gil Causey
AMA# 6964
« Reply #5 on: April 11, 2009, 03:57:51 PM »
Most machine shops I've worked in had their air piped up to the ceiling, then down to the floor, with a water drain there. A horizontal leg would be tapped off the down leg about at about chest height. The horizontal leg along the wall would have a rise to it, so that water would drain back to that down leg and the drain. This sort of thinking applies to our use, because it will take a lot of the water out of the air before it gets to your moisture filter. Your ambient humidity is a huge variable and may not be a problem in Tucson...or a real big problem in most of the Midwest, East, and SE.  y1 Steve
Offline Pinecone
« Reply #6 on: April 12, 2009, 08:58:03 AM »
Remember though, without active moisture control, the air coming out the end will be basically 100% relative humidity. Cooling it ambient helps make sure you don't get droplets spitting out of the gun.
When I finish plumbing my shop for compressed air, I will have a refirgerated dryer after the compressor.  Then a wall mounted dessicant system for painting.
Terry Carraway
AMA 47402
