  • July 30, 2025, 12:29:02 AM
Author Topic: Brass or Copper Tubing??????????????????????  (Read 1633 times)
Offline Robert Zambelli
« on: April 12, 2012, 09:17:50 AM »
This is a brand new piece of 1/8 inch brass tubing that I had in stock.
The photo tells it all.
Offline Brad Smith
Re: Brass or Copper Tubing??????????????????????
« Reply #1 on: April 12, 2012, 10:22:47 AM »
Nice piece off scrap BOB.
Brad smith AMA780054
Offline Larry Fernandez
« Reply #2 on: April 12, 2012, 11:08:48 AM »
Thanks for the post Bob.
A few weeks back I asked a question about this and Dirty Dan called me a "Wanker"
Larry, Buttafucco Stunt Team
Offline Garf
    • Hangar Flying
« Reply #3 on: April 12, 2012, 05:56:29 PM »
Here is what I found when I took a tank apart.
Offline Russell Shaffer
« Reply #4 on: April 12, 2012, 06:57:45 PM »
I've been getting 1/8 OD copper tube from an auto parts store.  It is on a roll and they sell it by the foot, about $1 as I recall.  It has a thicker wall and doesn't kink when bending.
Russell Shaffer
Klamath Falls, Oregon
Offline Warren Wagner
  • Bradenton, FL
« Reply #5 on: April 13, 2012, 08:34:31 AM »
And here's another example of the strange behavior of BRASS tubing.
This is a "feed-thru" for the top of a gallon fuel bottle, but the interesting thing
here, is that the worst breakdowns are where the brass tubing is in contact with
the VAPORS from the fuel, not the direct liquid fuel.
Any chemists here that can explain this behavior???  Could it be the close
proximity to the interface between the brass and the lead/tin solder used to
fabricate the fittings?
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
Offline Garf
    • Hangar Flying
« Reply #6 on: April 14, 2012, 09:32:20 AM »
This would be intended for use on auto A/C units.
ChrisSarnowski
« Reply #7 on: April 15, 2012, 05:26:02 PM »
How do you say "wanker" in Chinese or Pakistani?
« Reply #8 on: April 15, 2012, 05:29:52 PM »
    No, because I had pretty much the same thing happen with no solder.
    The theory has always been that the zinc gets leached out of the brass, leaving a spongy and brittle copper matrix that then breaks easily. I don't know the chemistry.
p.s. As always, wikipedia to the rescue:
"Leaching of zinc
"DZR" redirects here. For the jujutsu school, see Danzan-ryū.
The most common example is selective leaching of zinc from brass alloys containing more than 15% zinc (dezincification) in presence of oxygen and moisture, eg. from brass taps in chlorine-containing water. It is believed that both copper and zinc gradually dissolved out simultaneously and copper precipitates back from the solution. The material remaining is a copper-rich sponge with poor mechanical properties, and color changed from yellow to red. Dezincification can be caused by water containing sulfur, carbon dioxide and oxygen. Stagnant or low velocity waters tend to promote dezincification."
   The oxygen being supplied by the nitromethane and the water being supplied by your hygroscopic methanol.
« Last Edit: April 16, 2012, 01:35:02 PM by Brett Buck »
« Reply #9 on: April 16, 2012, 12:00:14 AM »
This is the question of the hour, of course.  Google Translate does not offer Urdu or Chinese written translations, but does have a Chinese spoken translation.  Yahoo Babelfish doesn't know the Chinese for wanker, nor does it translate anything into Urdu. http://dictionary.englishtourdutranslation.com/?english=wanker&submit=Translate gives   احمق
Hope this helps.
