  • August 03, 2025, 12:19:12 AM
Author Topic: blank  (Read 3800 times)
blank
« on: February 03, 2017, 11:44:03 AM »
blank
« Last Edit: March 06, 2022, 09:30:01 AM by Motorman »
Offline Walter Hicks
Re: Ro-Jet Vs PA Vs K77
« Reply #1 on: February 03, 2017, 01:52:23 PM »
I have a RO Jett .67  SE, and RE excellent ,not much break in required. I have two K 77  very little break in required per Kaz Minato and personal
experience. K 77 ,4 ground runs and fly. PA Motor is also excellent, requires more break in. No big deal they are made with different types of
metals on each one. You pick your  poison they are all very, very good motors well worth every penny you pay. Dave Fitzgerald PA 75 is one of the
most awesome stunt runs I have ever seen. Brett Buck RO Jett 61 runs like a sewing machine. I do not know anyone as of yet that has run the
K 77 on a pipe in the USA. Mine were run on muffler from Kaz. K 77 very smooth and user friendly. You cant loose with any of the motors. You do get
what you pay for with any of the above motors. RO Jett uses much less fuel but is a little bit heavier. My K 77, 11.9 oz on digital scale,
RO Jett 67  13 oz( Barstock longstroke ). They are all Mercedes Benz quality, fit etc, longevity. It is a win,win with RO Jett, PA, or K 77. I am not an expert flier, middle of the pack Advanced so you may want to hear from the experts, IE Randy and Dave for PA, Brett and Richard Oliver for RO Jett and Kaz,and Randy for the K 77. It is a win, win with any of the PA, RO Jett or K 77 they are just a bit different in run type.
Offline Allan Perret
  • Proverbs
« Reply #2 on: February 03, 2017, 06:06:19 PM »
Good write up..  So you are not an expert flier but you might be the only one on this forum that has real experience with all 3 motors.  I have the first 2 and a PA on the way, but no experience as of yet. Hope to remedy that this year..  But I did fly today and really liking my Enya61RE, very PA like run quality, too bad they are no longer available..
« Last Edit: February 04, 2017, 08:52:55 AM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #3 on: February 03, 2017, 09:01:58 PM »
Looking to hear from guys that have owned both Ro-Jet and PA. One seems to command a much higher price. Do you think they are on par with each other as far as fit, finish and weight? Does one need more break in, do they both hold their piston fit as well. If you like PA over Ro-Jet would you buy K77 over Ro-Jet? I don't want to get into vendor reputations just hardware performance.
     I presume you are talking about competitive engines (i.e. piped, running carbon props at relatively high revs).
     I have extensive knowledge of the RO-Jett and the PA series, haven't even seen Kaz's engine. Set up as I set them up, I much prefer the RO-Jett 61 BSE (the "Brett" version) over the PA61/65, not because of the quantity of power possible (the PA is generally more powerful-feeling than the RO-Jett) but the RO-Jett run characteristics are much smoother and more symmetrical, and has much less boost/brake in the maneuvers. It's easily adjustable to get how much you want. It's like a gigantic 46VF that you can still get parts for, which was noted for it's excellent run quality.
The PA61/65 is *much* better in most regards than the 40, mostly because it has so much more power, you can moderate the power variations and still have abundant power left over. The 51 is a completely different breed of cat, and several people with extensive experience with the 51 tell me that it is much more amenable to reducing the power bursts than any of the others. David's 51 setup still has the most static thrust of any competitive engine we have measured, although that means almost nothing other than bragging rights. It also wants to start backwards (at least the versions with the extended intake duration) and run hard that way from time to time.
   Comparing the RO-Jett 61 to the PA75, the 75 clearly has much more power capability, which means that some of the issues I had (and many other people had and still have, whether they recognize it or not). with the PA61/65 can be moderated with the 75 by detuning it. David's setup is very smooth and powerful and with some pretty simple parts modifications from stock, usually runs the same on insides and outsides. With the props he runs, it's just idling around.  There is a cost to be paid, in terms of heroic fuel consumption (like 8 oz/flight). If I couldn't get a RO-Jett 61, I would certainly get a PA75, and at this point, I think they are a wash as far as being able to give *me* competitive performance.
    Others will vehemently disagree with this evaluation, of course.
    Note also that, unless you go whole-hog, you can get perfectly acceptable runs from almost any of these engines. I am evaluating them in terms of getting the best possible runs at the highest levels of competition, and with whatever that demands. Anything from an Aero-Tiger 36 to any one of the 88s ir 91s will fly most competitive airplanes very well, certainly better than any engine you could have gotten before about 1988.
    And just like airplanes, the differences in ultimate capability of the engines you are discussing will be swamped by even slight errors and/or variations in the setup, and based on what I have seen, and with no offense intended, I would recommend one of the engines that has a very-well-established and repeatable setup so that you will have a good baseline around which to experiment.
   The recommended setups are pretty reliable and you can dial in any sort of run you would want within reason. And you can also dial it out. It's the old "if you can adjust it, you can adjust it wrong" phenomenon.  That's why I am always irritating Derek and others by suggesting the 40VF, because nothing is more likely to work using a canned setup by a neophyte than that, and it *never* has the excess power burst problem to any great degree - which is the biggest problem most beginning engine experimenters BY FAR.
Offline Chuck_Smith
« Reply #4 on: February 04, 2017, 07:17:40 AM »
I'll be running K77 with a pipe this year. I'm looking forward to seeing how it runs. Beautiful looking thing, that's for sure. So light and with the CF pipe Randy Smith hooked me up with it's going to hopefully be a great grunt-to-weight ratio.  I may just pull a clear Lexan cowl for this ship to show it off! <=
AMA 76478
  • Proverbs
« Reply #5 on: February 04, 2017, 09:03:19 AM »
Hey Brett: You have any experience or knowledge on the RoJett 67RE ?    RO has said it's the best stunt motor in his line up ..
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: February 04, 2017, 10:46:32 AM »
   No experience other than watching others. I know that they think it is better, but I have never had a stunt engine of any type that runs better than the 61.
« Reply #7 on: February 04, 2017, 05:21:50 PM »
  blank
« Last Edit: March 06, 2022, 09:29:26 AM by Motorman »
« Reply #8 on: February 04, 2017, 07:54:18 PM »
Brett, I think I remember you set up for a 424 with the pipe on the 61 Brett version? Ro-Jet claims the 67 is a stroked out 61 torque monster intended for muffler people. I don't know if my thinking is right but is the steady 4 stroke with muffler set up easier to operate?
       No, my setup runs in a 4-stroke more-or-less all the time, although, when it is off a bit, it runs across the break. That's the key feature that makes it better, when running across the break, the power difference is not excessive. That's the same as when Ted and David were running the 46VF with the Randy AAC, the breaks where extremely gentle, almost non-events, if everything else was right. That was always where we had issue with the PA61, I could never get it to run without excessive power change at the break without also losing power everywhere else. My best PA setup was also a constant 4-stroke as well. Someone at the 2001 or 2002 NATs came up and congratulated me on my great run, and how I had the best-running Saito on the field!
     Just so everyone is clear, the fact that these engines run in a constant 4 (or a constant 2) doesn't mean they are "constant-speed" engines. There is plenty of response in the maneuvers whether it changes state or not. The pipe response controls it, not the misfiring (or not) you get in a 4-stroke. I like the 40VF because you can easily adjust it to have a bit too much boost in the corners, or a bit too little, with dead-nuts repeatability with simple pipe length changes, and once you set it, it stays that way.  My current RO-Jett system is the best I have had, because if set correctly, it has just the right response, if I get a little fast, the response goes 'flat" to minimize the acceleration and make the maneuvers easier, and if it is set a bit too slow, it picks up enough boost to make up for the too-slow run. It also starts breaking in the maneuvers when set too fast, but that has almost no effect on the power.
       For the constant 4-stroke run, I adjust the prop diameter, venturi, and nitro to get it to run in a 4 throughout the flight. More diameter causes more feedback to the engine, and cause it to want to break more. A smaller venturi or less nitro causes you to run generally leaner, which puts it closer to the break to begin with. Less nitro reduces the power change at the break, more increases it, so you trade off how much nitro to either avoid the break entirely (more nitro) or let it break and moderate the power change (less nitro). On both the PA and Jett, I run *far less* diameter than the engine could otherwise handle. Both could easily be set up to run 14" props if you wanted to, but if you try to compete with Paul/David/Ted on a regular basis, you won't like your 14" prop (any more than Windy or others did...). I run a 12.5-3.75 3-blade with no undercamber, and at one point (2000 NATs, where I finished tied for 3rd), I flew with David's "break-in" prop - a 12-3.75 undercambered 3-blade that had been ground down on bad takeoffs to around 11.5". That was before we discovered that we should be running 15% nitro, so it took a pretty small prop to keep it in a 4 all the time.
    For piped engines, I think it is much easier to just adjust the overall capability up and down to control the operating point, rather than attempt to deal with the combination of pipe tuning regulation effects and phase changes at the same time. By far, the biggest issue I see is that people have their piped systems set to give FAR TOO MUCH boost/brake, and many of them have no idea how much it is hurting their progress, they don't know that you shouldn't have to panic when you turn the left top corner on the square 8 and the engine breaks into a screeching 2-stroke and accelerates you at the ground. I have flown airplanes that would go about halfway around a corner, break, and nearly pull the handle out of my hand, and the owner is thrilled by how much power they have. The judges are usually less-than-thrilled at the side effects.
     I haven't run my 61s (PA or Jett) on a muffler. Ted ran his 61 that way for a while and it ran fine, but he said it gave up a fair bit of performance that way. If nothing else, you are running it generally slower, meaning more pitch (~4.5-5" as I recall for Ted) and that alone means less performance in most aspects.
     I have only seen 67s with mufflers, and they also all flew well and ran nicely. I will admit that I haven't spent a lot of time with modern engines on mufflers, and certainly not enough time to see if the fiddle-factor is significantly improved over the good old days. The endless fiddling to get it to break at the right time and the right amount as the conditions changed was one of the big reasons everybody dropped them like hot potatoes as soon as something less labor- and knowledge-intensive came along. That was also of course when we were using engines like the ST46 and ST60 which sometimes acted like random number generators as far as what they did, or sometimes just went off the rails for no particular reason. And, you had to keep them running in perfect form because you couldn't afford to run them a bit "off" as the performance was too marginal to permit that.
    A modern super-engine like the 67 would very likely remove much of the randomness and certainly the power margin would be better, and maybe that would reduce the fiddling necessary enough to make it worth doing. But one of the reasons you can put amazingly powerful engines like the PA75 in a teeny little ST46-sized  airplane like the Thundergazer and come up with a world-beater is because you can control the power with the pipe and other adjustments.
      MANY people, not understanding this, figured, "gee, I can get a 91, why do I need a pipe?"  I figure you need a pipe even more with a 91 than with a 40 - because otherwise, you have to try to dump the 90% of the possible power, instead of maybe 25% with a 40. That's why Windy couldn't get the Jett 88 or 90, or whatever it was, to work - 1% too much and it was way too fast, 1% too little and it was way too slow. He switched back to a 76 in the middle of the NATs one year because of that. In the good old days, you absorbed power my making the airplane bigger, but we are already about as big as you can practically go. For a 91, you might need a 1000-square-inch airplane to give yourself some tolerance, but that's far too large to be practical in a 70-foot circle.
     That's more-or-less a core dump of my knowledge of the topic, most of us switched to piped engines because of the improved performance and reduced fiddling, and at this point, we have figured out a number of reliable systems and settings (which is what took the knowledge and evaluation skills). But I expect that unless you are trying to compete with others at a high level, the mere fact that any of these engines are of amazing high quality compared to what we had 30 years ago in the 4-2 break era will reduce the randomness enough to reduce the endless diddling required before, and provide very good performance.
      If you got in a time machine with two PA40SE's, set the controls to  1977, and handed them to someone like Ted Fancher, we would have retired the Walker Trophy at this point because he would have won every contest for the next 15 years (instead of just most of them...). That's because, compared to something like the ST46 or other engines of the time, even the least capable of these engines would have been an astonishing breakthrough. Heck, might have been the same if it was LA46s. Bascially anything you can get these days is better than the best stuff available back then, and will work better. So it kind of depends on what standards you are trying to achieve.
« Last Edit: February 05, 2017, 10:07:27 AM by Brett Buck »
  • Proverbs
« Reply #9 on: February 06, 2017, 07:10:41 AM »
Great info Brett, thanks for sharing..
Allan Perret
AMA 302406
Slidell, Louisiana
