General control line discussion => Open Forum => Topic started by: Gary Dowler on August 30, 2018, 09:40:48 PM
Title: Bought my first ARF
Post by: Gary Dowler on August 30, 2018, 09:40:48 PM
Innocently browsing in my local hobby shop today I found myself confronted with a Flight Streak ARF kit. Couldn't resist.   I'm amazed at the weight. Weighing it in segments including all hardware,  including my OS 20fp with muffler on it, it came to 25.3 oz. Same 400sq in as my Cosmic Wind, but 9oz lighter.
Guven tgat my Cosmic Wind isn't hurting for power with the 20fp at 34 oz, I'm thinking a 15FP is in order on this.
Anyone got a 15FP with muffler for a decent price?
Gary
Title: Re: Bought my first ARF
Post by: Brett Buck on August 30, 2018, 10:25:25 PM
   It will go better with the 20, although it would probably fly OK with the 15.
Post by: Gary Dowler on August 30, 2018, 10:38:57 PM
Thank you, Brett. I'll look for a second one.
Post by: John Rist on August 31, 2018, 04:37:53 AM
They do pop up on eBay?  https://www.ebay.com/itm/OS-MAX-20-FP-R-C-NITRO-MODEL-AIRPLANE-ENGINE/253830518863?hash=item3b197a584f:g:W9QAAOSwwVBbgGoD.
Needs NVA
Post by: Gary Dowler on August 31, 2018, 02:35:06 PM
Needs NVA
Thanks. I won that auction!  Now to order a NVA and Venturi
Post by: Tim Wescott on August 31, 2018, 02:56:53 PM
In the mean time you can wire the throttle open.  It takes a bit of dinking with to get the opening right.  On some engines (I dunno about the FP) you can flip the barrel around and use the idle stop screw as a setscrew, or you can hold them open with a spring against the idle stop screw.
I wonder if you could put the carb back on eBay & get some money for it?
Post by: Peter Grabenstein on August 31, 2018, 09:35:15 PM
IMHO and Memory,
too short motormounts,
too soft fuse plywood doublers,
flimsy nose section,
keep an eye on "well balanced" prop,
plastic spinner tend to vibrate,
 I would epoxy one hardwood Triangle between left/inside fuse doubler and
wing leading edge to stiffen the nose section.
One of my flying buddies broke off the nose by a snap.
SORRY: IMHO …..this ARF should be modified.
Sorry my English is not so good this time.
 H^^
Post by: Gary Dowler on September 02, 2018, 12:37:09 PM
Got another OS 20FP enroute.  The one I won (ebay) had a carb, so I ordered a venture and NVA set for it.   Its a kit with a derlin venture, and for reasons I don't understand, a Enya nva including special drill bit.  Hope this works......
Gary
Post by: Dane Martin on September 02, 2018, 12:50:14 PM
Gary
Oh! I got your pm, but please don't drill the case! I'll trade you for the correct stuff or something like that if you'd like
