  • June 21, 2025, 08:05:34 AM
Author Topic: Balsa Fillers  (Read 3253 times)
Mike Griffin
Balsa Fillers
« on: July 21, 2013, 10:00:15 PM »
What different types of balsa filler do you guys use?  For example to fill cracks in sheeting or small divots.  I have used spackling, Super Fil but not really satisfied with either....
Offline Balsa Butcher
  • High Desert Flier
Re: Balsa Fillers
« Reply #1 on: July 21, 2013, 10:55:00 PM »
Elmer's Carpenter's Wood filler works good for cracks in sheeting.  Red bondo - in small (as in pinhole) quantities. Water and a mono-kote iron to steam out small divots and scratches. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Re: Balsa Fillers
« Reply #2 on: July 22, 2013, 01:08:36 AM »
I've had trouble in the past with dope not wanting to go over Elmers...bubbling and not sticking.  Both Nitrate and Butyrate.
Too bad because the stuff is easy to use and looks great until the dope is put on.
Offline GregArdill
Re: Balsa Fillers
« Reply #3 on: July 22, 2013, 01:15:03 AM »
I use Cabot's Wood tone Putty. Light enough for small dings, and doesn't shrink with dope.
Sands to about balsa colour, for those wanting a clear finish.
Greg
Offline Bootlegger
Re: Balsa Fillers
« Reply #4 on: July 22, 2013, 05:37:11 AM »
  Greg, where do ya' get the Cabbots wood tone putty?
 Thanks, Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Allan Perret
  • Proverbs
Re: Balsa Fillers
« Reply #5 on: July 22, 2013, 07:29:56 AM »
Automotive spot putty, its lacquer based and dries real fast.  You can sand it in 5-10 minutes and its sands real easy.  There is a small 4oz tube sold under the Bondo brand label in Walmart for about $5.   At the auto body supply places the smallest tubes are like 10 oz plus and will be around $15.
Allan Perret
AMA 302406
Slidell, Louisiana
Mike Griffin
Re: Balsa Fillers
« Reply #6 on: July 22, 2013, 08:31:41 AM »
Allan is that the stuff that is red in color?
Online Gerald Arana
Re: Balsa Fillers
« Reply #7 on: July 22, 2013, 09:26:41 AM »
Mike,
I've been using "MICRO-FILL" by North East Hobby Products. Its a balsa colored model filler and I like it a lot. Sands easy and I haven't had any problem that I know about. Been using ALL Brodak buterate dope.
Cheers, Jerry
  • Proverbs
Re: Balsa Fillers
« Reply #8 on: July 22, 2013, 09:31:27 AM »
Yes, the "Bondo" tube I have now is like a red oxide color.  Label on the tube says "Glazing & Spot Putty".  I think I once had a larger tube of the 3M brand that was grey.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline GregArdill
Re: Balsa Fillers
« Reply #9 on: July 22, 2013, 05:08:33 PM »
 Thanks, Gil
Gil,
Cabot's is an Australian company.
Here's a link to the product http://cabots.com.au/product-detail/1465/prep-products/wood-tone-putty
You might be able to find an equivalent US product.
Greg
Mike Griffin
Re: Balsa Fillers
« Reply #10 on: July 22, 2013, 05:11:50 PM »
Gil Lowe's carries Cabot products..
Re: Balsa Fillers
« Reply #11 on: July 22, 2013, 05:32:24 PM »
Mike,
   Is this the super-light water-based stuff? Like Model Magic (AKA Model Tragic)? Beware, Model Magic and the equivalents will work moderately OK in very small cracks but they are not compatible with dope and will soften up.
   I have had no luck at all with any of the water-based products, they seems to shrink or grow as they choose. The red glazing putty usually works out a lot better with dope.
Re: Balsa Fillers
« Reply #12 on: July 22, 2013, 05:33:17 PM »
Hi Mike,
The Bondo and Nitro Stan products are a dark red.  The large 3M tubes are green, blue, and one I forget.  The different 3M colors are for their "grain" or how smooth they are when dry.
Mike Griffin
Re: Balsa Fillers
« Reply #13 on: July 22, 2013, 09:48:03 PM »
Thank you all for your input..
  • High Desert Flier
Re: Balsa Fillers
« Reply #14 on: July 23, 2013, 08:37:41 AM »
Based on one specific recommendation I am going to re-consider my use of the Elmer's product.  Thanks for the heads up. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Online Gerald Arana
Re: Balsa Fillers
« Reply #15 on: July 23, 2013, 09:29:45 AM »
Brett,
Yes, it is the water based stuff. I use it in small areas. I use epoxy/milled fiber glass in larger areas. Yes, I know epoxy is heavy.
Lately I tried "Super-fil" and I think I might be using that a lot....... Almost have the Ringmaster ready for dope.
Later, GA
Online Gerald Arana
Re: Balsa Fillers
« Reply #16 on: July 23, 2013, 09:37:50 AM »
Well that underline didn't work the way I wanted it to. DUH. ???
Maybe some day I'll figure out how to work this "stoopit" computer.  y1.......... Maybe not.
GA
