I can't believe I'm going to say this,,,,
My problem with the BOM interpretation would become critical, if it were to allow, what would basically be "turn key" operations.
Anytime a person could purchase, and it can be done right now, a plane that is completely assembled, even if it's a take apart design, and do nothing more than bolt in an engine, tank, and hook up the lines, it would definitely not be, in anyway considered a "kit". You can purchase a cased airplane, that is so complete, it has even been test flown, and basic trimmed. Same goes for purchasing another pilots used airplane, or having one built by another builder. None of these should be considered a kit, or a BOM qualified plane.
Now, considering the current ARF's and ARC's.
I believe that the state of kits, in the entire hobby, has progressed to the point that a many of them are close to, if not in fact, ARF's and ARC's.
So, where does that leave me, a supporter of BOM?
OK, components are components. how they are tied together, in my opinion is where the skill needs to be applied. Let me illustrate my thinking on this subject of installing components.
There have always been several axioms decreed by the stunt Gods as sacrosanct when it comes to the aircraft, and these are. 1.Build only as strong as needed. 2,Keep the weight under control. 3,Straight is great, meaning that proper alignment is crucial. and 4.use a dependable, reliable, and correct power package.
Of the above axioms, we've found that many pilots over build, and get away with it. They also have shown that with proper setup and power, an overweight porker can still bring it home. It's also apparent that what is considered dependable, reliable, or correct, in the choice of power, is also not set in stone. Of the 4 axioms noted above, we're left with straight, proper alignment.
So, in my current thinking, an ARC, and quite possibly, an ARF won't be any good, no matter the quality of the "kits", if they are sloppily assembled. Badly assembled components make for poor flying planes.
Properly assembled components, regardless of where they came from, can become outstanding planes.
Does it make a difference that the components come in a "KIT"?
Until the advent of real ARC's and ARF's in CLPA, it was a common, and regular occurrence to purchase components and assemble them into a design. Many of these were considered "Scratch Built," Or even "Original" designs.
The components, such as prebuilt engine crutches, framed up built up, or salvaged wings, foam wings complete to the point that sometimes the flaps were even installed, as well as stabs and elevator cores, only, or sheeted.
Having said all the above, I would prefer that it would be necessary to do a lot more of the work to qualify for BOM, but the facts are that a creeping acceptance of components has taken place, and been accepted, under the current rule. I can see where some, whom I feel are only asking for codification, perhaps to defray future criticism, are now asking to either rewrite the rule, in light of what has become common practise, or eliminating it altogether as unenforceable.
I'm not sure that the rule is unenforceable, but it is confusing due to the issues cited above.
There are several possible solutions, in my opinion, that would serve.
One would be to go to FAI rules and let the argument go. The problem seems to be that under FAI, we would lose some of the control over our own events to a committee based overseas. Americans being what we are, that's a difficult pill to swallow, esp. since the event was born here.
Drop BOM completely from US CLPA events, along with appearance points.
While this would please some, it would not please the majority of US competitors. Another area of concern is with the National Championship. This is the only contest where not being the BOM, will not allow you to compete. Anyone can compete with any airplane under PAMPA classes, sans appearance points. It makes me question the motives of some anti BOMers. Do they want to drop BOM, or simply get rid of the appearance points so they can compete without the hit of loss of a few appearance points.
We could leave it all as it is, and continually have this conversation. In my opinion this is the worst suggestion of them all.
We could rewrite the rule. It could be quite simple, and I offer the following.
A. Builder of the model requirements shall be considered completed when the following has occurred.
The pilot shall have assembled and aligned the components.
Components are defined as:
Motor crutch, wing, whether built up, or foam, sheeted or not, Stab and elevator, either built up or foam, sheeted or not. Control system, individual or assembled parts. Gear, pre-bent or ready to mount. Movable control surfaces may be shaped and ready to install. Basic fuselage may be ready to accept components.
Edit> Components may be purchased or built by the builder.
Assembled and aligned are defined as;
The installation of accepted components in proper alignment as to maintain a safe flying plane.
B. Appearance points:
A total of 40 points to be possible.
Appearance points when used, shall be awarded based on the following points.
Planes eligible for AP's must conform to the requirements for BOM.
Originality: points given for presenting a new, or modified design, showing original thinking and, or, execution. Available points, 1-20.
Workmanship: Points given for quality and good workmanship exhibited by the builder. Available points, 1-20.Now, you've noticed that I suggested 40 appearance points. This is an arbitrary number, but I like the concept of rewarding Originality with an equal amount of points as are given for construction.
If the above seems reasonable, let the powers that be in PAMPA know, and we can make a proposal for a rule change.
(Yeah, Randy, I'm finding it hard to believe I also said that. Something needs to be done, and we have to end this constant BOM discussion. Expanding the appearace points allows for more latitude, and reward those who still are modelors, even when building and ARF, or ARC.)
