Check alignments. Make sure the vertical tail, fuse, aren't offset, even slightly towards the center. Also check for wing warps or misalignment's between the stab and wing. Wing warps can be twisted out of a Banshee (or Twister) fairly easily. Since the wing isn't a D or C tube. If you're flying outboard wing high, upright and inverted, slit the wing tip and glue in tip weight. You can either mount a tip weight box by cutting and patching the outboard wing, or simply slit the covering on the wing tip, glue in weight and seal the slit with clear packing tape. Once you've got the trim right. You can patch the slit with silkspan or monokote. If your stab is off alignment, either cocked up or down, or misaligned looking down from the top view, wing tip/stab tip closer on one side or the other, cut the stab loose and re-glue. You can add engine offset with either offset wedges (Brodak has them) or washers under the front mounting screws. Lead outs can also be adjusted, if need, by slitting the covering and re-gluing the lead out location. I've never seen a pristine Banshee. Don't be afraid to scar your pride and joy, while making improvements to trim. Adds character.
