  • June 25, 2025, 05:01:03 AM
Author Topic: Prop diameter vs line tension  (Read 2870 times)
« on: November 21, 2010, 09:16:17 AM »
Guys,
What has been your experience with varying prop diameter vs line tension vs lap time vs wind penetration? I know the basic idea is the larger the prop diameter the better the line tension, square tips more line tension. However how does the prop diameter impact the need for lower lap time for wind penetration? If you use a 13" diameter on a full size ship (700 sq's) could you fly lower lap time then if you used a 12"? It seems this might work, what's your experience?
Best,              DennisT
Offline Dick Pacini
Re: Prop diameter vs line tension
« Reply #1 on: November 21, 2010, 10:19:36 AM »
Prop diameter gives traction. Prop pitch controls speed.
AMA 62221
Offline Larry Fernandez
« Reply #2 on: November 21, 2010, 07:01:59 PM »
Larger props can induce gyroscopic precession and adversely effect the planes cornner.
Everthing we do to our planes is a compromise.
Larry, Buttafucco Stunt Team
Tags: props
