  • July 09, 2025, 12:20:26 AM
Author Topic: BJMR Hi Johnson Stuka Kit  (Read 2063 times)
Offline petermick
« on: November 10, 2015, 03:44:47 PM »
Hi All,
I am interested in building an electric version of the BJMR Stuka.  I came across a very negative review of the kit which stated that the only useful items in the kit were the canopy and the plans. These comments seem to have originated in Australia.  Before I spend $164.00 for the kit I would like to know if anyone else has had a bad experience with this product?
Peter Mick
AMA 9581
Offline steve bittner
Re: BJMR Hi Johnson Stuka Kit
« Reply #1 on: November 10, 2015, 05:14:31 PM »
This is not like the Hi Johnson stuka, only thing close is the wing. I have Hi Stuka and original plans, fuse is not same measurements nor stab, push rod is outside, fuse has different movement . I bought a BJRM kit and was disappointed for sure.  The wing is a lot of work to build for a plane that doesn't turn good. Make me an offer and I may sell the kit to you, never been touched. There is a lot better planes to build for electric.
Offline petermick
« Reply #2 on: November 11, 2015, 09:24:50 AM »
Hi Steve,
Thanks for your response.  Now I have seen two negative opinions.  The other kit I am considering is the Brodak Vector 40.
Peter Mick
AMA 9581
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: November 11, 2015, 10:21:37 AM »
The Vector 40 kit is excellent. Well engineered, relatively easy to build, and winning design. Many have been both in both IC and electric configurations. Another good one along the same lines is the Legacy 40. Yes, I have built both.8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Larry Fernandez
« Reply #4 on: November 12, 2015, 10:22:31 AM »
Does anyone happen to have a picture of the BJMR Stuka canopy.
I've got a Hi Johnson wing built and covered and I don't much feel like making a plug to pull a canopy.
If you really want to test your modeling skills, build a Hi Johnson Stuka sometime. The wing is an absolute nightmare.
Larry, Buttafucco Stunt Team
  • High Desert Flier
« Reply #5 on: November 12, 2015, 11:09:43 AM »
Picture at "BMJRmodels(dot)com". Note BMJR not BJMR. Plane looks nice, canopy not very detailed but appropriate for stunt plane. Write up states ribs have tabs so wing can be built on flat surface which would make it a lot easier to construct than the original. Surprised there is not more interest in this kit although the high price and classic era time frame with less than Nobler performance may have something to do with it.  8)
Pete Cunha
Sacramento CA.
AMA 57499
