  • June 14, 2025, 09:37:36 PM
Author Topic: Binding at the handle?  (Read 2162 times)
Online Paul Taylor
« on: May 19, 2014, 07:27:28 PM »
I got a few flights before sunset today. I have been getting a little popping or clicking at the handle. I thought it was the line clips. I changed the clips at the handle and it seemed to help a little. I then tried tubing over the clips. But still today a few good pops. It's like on the outside loops of the vertical eights and hour glass.
Anyone experience this before. Plane does not seem to do anything weird.
Offline Crist Rigotti
Re: Binding at the handle?
« Reply #1 on: May 19, 2014, 07:35:52 PM »
I'd cut off the excess bolt length form each side of the handle.
Online Paul Taylor
« Reply #2 on: May 19, 2014, 07:59:49 PM »
Thanks Crist!
Will hack them off.
« Reply #3 on: May 19, 2014, 08:07:58 PM »
TED Handles don't do that!  LL~ Steve
« Reply #4 on: May 19, 2014, 08:36:51 PM »
  I agree with cutting the excess bolt length off, and the cable on the handle doesn't need to be that long either. I had similar experience with a handle on my Twister/Shark and finally figured out that it was the bolts twanging the cable. It was at that time also that I decided that the cable only needed to be long enough to allow for an inch or two of movement to attain a neutral control setting. The shorter length helps eliminate the chance of the line clips hitting each other.
« Reply #5 on: May 19, 2014, 09:19:04 PM »
I had a few of those handles.  I didn't like the spongy feeling from the heavy cable, it'll flex differently at different times.  Also didn't much care for the overhang.  Flying with a Hot Rock felt better.  I made up a couple hard point Hot Rock knock offs and sold the Brodak handles on Ebay.  They're great for trimming, since they're so adjustable, but they're fairly rotten for flying the pattern consistently.
If I had to guess, I'd venture that the cable is pulling through the slider blocks during times of harder pull, and springing back when the tension lessens.
Offline Larry Fernandez
« Reply #6 on: May 19, 2014, 09:35:44 PM »
Why bother wasting your breath.
Larry, Buttafucco Stunt team
Online Paul Taylor
« Reply #7 on: May 20, 2014, 11:51:43 AM »
Thanks guys.
Changes are coming.  H^^
« Reply #8 on: May 20, 2014, 09:03:52 PM »
It's the price of the typing paper and correction fluid that really hurts.  LL~ Steve
Online Paul Taylor
« Reply #9 on: May 21, 2014, 06:08:26 PM »
Cut the bolts off. No popping at the handle!  Thanks guys!
