So how does one determine if a piece of balas wood is nice weight or too heavy? What is ment by 4lb wood and so on? What kind of wood is in a Brodak kit? Can you build a Brodak kit light?
I bid on a box of modeling stuff an it had a old Tower Hobbies box of wood that says Grade AAA. What does that mean? Some of it feels heavy but what do I know.
Balsa has essentially two characteristics - density and grain. The density is as it sounds, usually expressed in lb/cubic foot. Under 6 lbs is usually considered "contest grade", and very light, 6-10 is medium and above 10 is hard. This is a general characteristic of the tree it was cut from, and how it was dried.
Grain is the direction of the with respect to the "flat" side, and depends on from where in the tree it was cut. "A" grain has the grain running across from one flat side to the other, will easily bend across in line with the grain. "C" grain has the grain running nearly parallel to the flat surface, and is very stiff to bend across the grain, and if you try, it splits. "B" grain is in-between.
People spend a lot of time worrying about the density, and sometimes don't pay any attention to the grain. You can build the same weight airplane with almost any wood, because the heavier it is, the stronger it is, and in most places you can just make the part out of thinner stock and get the same weight and the same strength of the completed part. Getting the right grain for the part is sometimes a lot more important. You would want C grain for fuse sides and solid flaps, and you want A for sheeting curved surfaces and spars. You almost always want light wood for blocks and medium for sheets.
Ultimately, it's nice to have the best 3.5-lb of the perfect grain for everything, but it doesn't make all that much difference. How the material is used and the cleanliness of the workmanship is far more important.
