By the term "RPM drop" we can't tell if it's slowing down rich or slowing down lean. I'm guessing it's going rich from your description. An engine should go just a bit rich in the air if all the fuel system is right and tight due to centrifugal force. usually takes at least a whole lap to settle in.It's possible that you had some sort of restriction previously that has cleared out, and now you have a lot more fuel in the mixture. I would change your fuel lines like you plan (check the pick up line in the tank if possible), then fly the model again. Check the tank height to make sure it isn't too high, but I doubt that is the problem. Get another experienced ear to go with you to help determine if it's going rich or lean and that will help you go in the correct direction, and change only one thing at a time.If you change a bunch of stuff and the problem goes away, you won't know what fixed it. To me, the big thing is to figure out of it's going rich or lean, and you should be able to tell the difference. Since it's doing it once it is up to speed in flight, I'm betting on it going rich.
type at you later,
