  • June 22, 2025, 10:31:31 AM
Author Topic: Bi-Slob Prop on a Fox 35 ????  (Read 4637 times)
« on: May 22, 2008, 06:37:30 AM »
Anyone flying a Bi-Slob with a Fox 35? If so what type and size prop are you using.
Paul  H^^
Online James Lee
Re: Bi-Slob Prop on a Fox 35 ????
« Reply #1 on: May 22, 2008, 07:09:03 AM »
Best prop for mine is an old TopFlite 10x6 paddle...   But, they are getting a bit scarce....    and I tend to fly a bit   ~^ ~^   toooo close to the ground...    LL~ LL~ LL~   the yellow KF from Germany was good also but haven't seen them for a while either...   The old Master Airscrew really sucked...    FWIW
Later
Jim
« Reply #2 on: May 22, 2008, 08:04:23 AM »
Maybe the question should be.
What is a good common prop to use on a Bi-Slob with a Fox 35?
Offline Garf
    • Hangar Flying
« Reply #3 on: May 22, 2008, 08:07:23 AM »
Later
Jim
The KF prop is available thru Hobby Lobby.
« Reply #4 on: May 22, 2008, 08:37:04 AM »
I like to use somewhere between a 9.5 and 10" prop, usually 5 or 6 pitch.  Lately I've been using ratty used APC's with the tips ground down... I seem to have an endless supply from buying used RC engines, and odd lots on Ebay.  They get cleaned up, rebalanced, and subjected to grass cutting duty on the Bi-Slob.  I ran an APC 9.5x6 for a long time and it worked well.
Alan Hahn
« Reply #5 on: May 22, 2008, 09:14:47 AM »
I'm using a Brodak BYO prop---they are available. I save my un-obtainium TF props for other planes where the probability of breaking the prop is less. I'm guessing the a Zinger 10-5 or 10-6 would be fine too. I don't say these are optimum, but I am not sure how much optimum matters on the Bi-Slob. n~
Offline Marvin Denny
« Reply #6 on: May 22, 2008, 09:43:58 AM »
  Of the five bi-Slobs I have built ,  all have performed very well on  10 X 5 APCs.  Other props I have used performed well, but not as well as the 10 X 5  APCs.  The fuel I run is fox Superfuel.
  Bigiron
marvin Denny  AMA  499
Offline John Paris
« Reply #7 on: May 22, 2008, 10:42:08 AM »
BigIron has it right on the money.  10x5APC is the prop of choice for Fox 35 stunt in most applications.
John Paris
269
Offline Keith Spriggs
    • khspriggs
« Reply #8 on: May 22, 2008, 10:43:58 AM »
  Bigiron
Exactly the combo I used last time. FUN  FUN  FUN.
« Reply #9 on: May 22, 2008, 11:45:53 AM »
  Bigiron
Thanks Bigiron, ( and others)
We broke the one that you had on there some time ago and I could not remember what size it was. I just found out that all props are not the same. MA may be the cat's meow for one setup but not another.
APC 10x5 will replace the MA that is on the Bi-Slob now.
Paul  H^^
Alan Hahn
« Reply #10 on: May 22, 2008, 03:58:13 PM »
  Bigiron
Just out of curiosity, what is it that makes the APC 10-5 work so well? Of course I could simply put one on and see for myself, but like I mentioned before in my post, I'm not sure what really matters---as long as you can adjust the Fox to give you the thrust you want.
I'll be bringing mine to Sig to fly after the Saturday dinner, so I hope others do to. I'd like to see what other folks are doing with them.
Offline gary tultz
« Reply #11 on: May 22, 2008, 04:45:47 PM »
John (Barefoot) Paris has it right. APC is the prop. Although we use 10/4 on Foxes. A good Fox has no problem with High rpm/ low pitch. There is a reason the 3-D r/cers use low pitch. Its spelled --HOVERING. Try a 10/4 APC.  y1 H^^     Rainman  aka  Gary T.
« Last Edit: May 22, 2008, 05:15:34 PM by gary tultz »
Offline Allan Perret
  • Proverbs
« Reply #12 on: May 22, 2008, 05:05:25 PM »
My Slob has an OS 25FP, and it works good with a 10-4.
Allan Perret
AMA 302406
Slidell, Louisiana
Alan Hahn
« Reply #13 on: May 22, 2008, 05:35:22 PM »
It isn't that I can't hover
[youtube=425,350]nPkzB_qo7hE[/youtube]
and I fly Electric 3D, so I understand the concept, so is what people are saying is that they prefer running the Fox a bit leaner than I do?
« Reply #14 on: May 22, 2008, 06:36:31 PM »
I don't know about anyone else, but I run a standard vented tank and launch the plane running so fat it'll barely get off the ground.  Due to the normal RPM change with the tank, the end of the flight has the engine running much faster.  It allows a wide range of engine performance allowing for a fun flight with lots of variety.
Alan Hahn
« Reply #15 on: May 22, 2008, 07:36:12 PM »
Andrew,
That is more or less what I do. That video of mine was the first flight this year. I didn't touch a thing on the Fox. I took off the tank compartment cover and checked to see if the 4oz Sullivan klunk looked ok (plumbed as a CL "Standard"), filled with Sig 5%Nitro, 25% Castor, and started it. Ran pretty good. As I fly more during the season, I tend to get more daring. Sometimes it is so rich, it almost won't take off. So in that case you can do a lot of hovering like stuff, and as it leans out you can go for the endless wingover! This flight was a bit leaner since the air was somewhat cool (in the 60's at most), so there was more O2 available.
I am curious to see what other guys are doing. My question about the APC was more whether it is the pitch, or maybe the heavier prop, or maybe it is just a better overall prop. I am not sure about the pitch of my BYO. The label has worn off and I am too lazy to pitch it! I do have a bunch of old Top Flight 10-3.5" Pitch props I might try, basically because I don't have any other use for them.
Anyway it is a hoot to fly these things. I probably haven't tried hard enough because I am still on my first one and haven't really crashed yet! And the Fox is just amazing!
« Reply #16 on: May 22, 2008, 10:20:49 PM »
I'm on my second Bi-Slob, almost my third if you count recycling the wings and stab/elevator with a new fuselage.  My first Slob was back in 93 and I burned up all 9 lives in a flash.  The wings and tail pieces made it through two fuselages before there wasn't anything left to glue back together but CA and castor soaked balsa...  I passed the intact wings and stab/elevator on to another club member when we moved in 95.  My second Bi-Slob was 2 years old in January.  Up until June of last year it hadn't been crashed, but it yo-yo'd on the lines, came across the circle and cartwheeled in, raining chunks of balsa.  I counted 23 individual pieces. The wings stayed intact, so it was a fairly quick fix.  So far this season I've wiped the rudder off twice, and broke the stabilizer loose during a rough touch and go.  The nature of the Bi-Slob lends itself to repairs, and the crashes are usually spectacular!
I don't know that I'd consider the Bi-Slob to be too picky about props.  I run whatever I've got around.  My first was flown with Master Airscrew 10x6's.  When I put the current Slob together, I had a bunch of APC's with fouled up tips, so that's what I've been using.  The 10x5 APC makes for a really nice run on a Fox 35, for whatever reason.  I don't think that it matters too much on a Bi-Slob, but it's probably as good as any other choice.
« Reply #17 on: May 23, 2008, 03:40:29 AM »
10x6 3 blade Grey Grish tornado nylon prop - they are virtually unbreakable and suit the slobs I have built and flown with a dirty old fox on them
Offline Just One-eye
  • Another Old Fart
« Reply #18 on: May 23, 2008, 03:59:32 AM »
I suppose you mean silver.  There was only black, white, and silver.  I'm pretty sure that the white & silver were the same soft plastic.  I wouldn't mind knowing where a few of those 10-6 silver tri-blades could be purchased, now that Tony Jr. finally gave up his half-hearted try at keeping Grish going.
Incidentally, for a Fox 35, I would choose the Tornado 9-6 tri-blade, rather than the 10-6.
Offline Jim Nohsey
« Reply #19 on: September 10, 2017, 12:09:14 PM »
Hey I'm seeing that some are running apc 10x4, 5 and 11x4 props on fox 35.  any other suggetions?
Warning: this topic has not been posted in for at least 120 days.
Unless you're sure you want to reply, please consider starting a new topic.
Jim Nohsey
« Reply #20 on: September 10, 2017, 03:22:33 PM »
I use an 11x4 APC prop on a Fox .35 with my Bi-Slob.
