As has been published, I flew Antone Kephart's model at VSC. That is the plane on the box art. My advice to you is to keep it as light as possible and add power! He used a McCoy 29 (not a .35 as reported) and although adequate, being able to swing a bigger diameter prop to generate more thrust (not speed, use a lower pitch) would go a long way toward better flying in the pattern.
The problem is stalling. You need thrust (see BiSlob threads) to pull a draggy, inadequate lift plane through those square bottoms. Think about using the plane to aim the propeller and you won't go wrong. Look at all the (ugh!) R/C 3-D flyers for a clue.
I scored a 404 in clearly national level competition with Antone's model, and lightened, with more low speed thrust, it could have done better. Note that the highest I have ever scored in "good" judging is 485. So the model has some real potential.
