I've built a fair number of FP .40 profiles. You may find my nose construction a little different, but it looks good, and it works!
On the out board side I use Frank Tiano's Mighty Lite 1/8th inch plywood. This is NOT lite ply! But it is strong, and lighter than 5-ply.
Inboard, no plywood, rather a 1/2 in. tripler back to the mid-point of the wing. Sand in a taper where it flows into the fuselage. Note, this provides a 1 inch thick nose/wing jount. Epoxy, of course. You can hollow out the area of the tripler ahead of the wing joint, and fair it into the spinner, and add a lower "scoop" if you choose. It'll also hide those ugly "Tee" nuts from the Motor mounts! You can sandwich in some C/F if you choose, but I really never have.
I'll see if I can't scare up some pics...
Ward
