  • July 15, 2025, 03:23:46 PM
Author Topic: Best WOOD prop for sport flying.  (Read 6290 times)
  • Gravitywell
« on: March 07, 2010, 05:33:57 PM »
These may not be the best wood props in the world, but they are reasonably priced.  And what I mean by SLIGHTLY modified is changing a tip shape, or slightly reshaping the blade.  NOTE!! By the modify, I do not mean balancing as I assume this is done with every prop. I like wood props cause I'm a bad flier and they absorb more damage when I land poorly! HB~> LL~  So cast your vote and don't be afraid to say why you like them. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Larry Fulwider
Re: Best WOOD prop for sport flying.
« Reply #1 on: March 07, 2010, 05:55:44 PM »
An APC dyed brown  ;D
       Larry Fulwider
Offline jimmy Hnat
« Reply #2 on: March 07, 2010, 06:21:37 PM »
You can dye a APC PINK,just bye PINK ritt dye,add Alcohol and let sit overnight,Pull the prop out,Drink the Alcohol and go fly.....Jimmy  PS dont drink the Alcohol it will turn your teeth PINK !!!
« Reply #3 on: March 07, 2010, 06:29:15 PM »
RSM props - without a doubt.  11 x 6 on an LA 46 - killer!!
« Reply #4 on: March 07, 2010, 07:05:01 PM »
I voted for RSM, but would really prefer to use a plastic propeller. Thunder Tiger Cyclone #1, Graupner #2 and APC #3.  The thing is, tho, that APC has a lot more useful sizes than the other two. All work VERY well, if you happen to have an engine/plane that needs a size that is available from them. I don't care about what a propeller looks like, if it works. Especially don't care about what color it is. Spinning at about 10,000rpm, they all look pretty much the same...dangerous!  LL~ Steve
« Reply #5 on: March 07, 2010, 10:19:41 PM »
The part that Gravity well did not say is that wood props are lighter too, and on his current project, the lighter prop will help his balance with the plane,,
Offline alan roadknight
« Reply #6 on: March 08, 2010, 04:34:06 AM »
have great success with Hawk wood props but can be hard to get
  cheers
   Al
« Reply #7 on: March 08, 2010, 05:55:44 AM »
I didn't vote as half of lthem I have never used.  And like gravity well I have a tendency to break them on landings. D>K H^^
Offline dale
« Reply #8 on: March 08, 2010, 02:28:05 PM »
Has anybody tried Vess wooden sport props, They come in sizes 9,4 and up.
Offline Terrence Durrill
« Reply #9 on: March 08, 2010, 04:37:27 PM »
I like the old paddle blade, round tip wood Top Flite props.  I use a 10/5 on my Fox .35 Barnstormer.....works great.  Of course, you have to find them at garage sales or buy them off Ebay......TDurrill   S?P
« Reply #10 on: March 08, 2010, 09:26:21 PM »
Dale,
I have used the Vess props a couple times. Seem to be a very well made prop, and very closely approximate an APC in shape. Not the least of the good things about them, they come with a VERY nice finish, and every one I have checked has been balanced right out of the package.
Offline dale
« Reply #11 on: March 09, 2010, 01:02:49 PM »
Thanks Mark,I have a brodak shark 402 that i am starting to build.It will have an enya ss30s for power,I was thinking of the APC 10.5 by 4.5 or a VESS 10 by 4. Do you think that the Vess is as efficient as the APC. TIA.
Offline Phil Coopy
« Reply #12 on: March 09, 2010, 03:22:06 PM »
I like to use a 26X10 BOLLY cut down to 11X5.  Bit expensive, but it helps take up the time between possible flying days lately.  You can also use all that CF dust with epoxy for some nice looking fillets (cough,cought..I gotta get a mask). Oh, you said wood. n~ LL~
Phil
Offline Jim Thomerson
« Reply #13 on: March 09, 2010, 03:38:48 PM »
The fact of the matter is that the prop which works best on your engine and airplane is the prop that works best on your engine and airplane.  The only way to find this out is to buy a bunch of props and fly and try.
Offline Scott B. Riese
  • Just a student of stunt
« Reply #14 on: March 09, 2010, 08:53:41 PM »
QUESTION was "Wood Prop For Sport Flying". GEEEE Guy's  HB~>
Zinger...
Master Airscrew....
Just make sure it's Balanced.
That's what I use for my Sport Fun. Bi-Slobs, Flounder....
NO way am I going to put on a $30 prop just to have fun with.
Scott Riese
Portland, Oregon
AMA 528301
« Reply #15 on: March 10, 2010, 08:18:20 AM »
Zinger...
Master Airscrew....
True enough, Scott. The thing is, that the better the prop works, the longer your plane last! I'm awestruck by the Thunder Tiger 11 x 4.5 on my Magnum XLS .36...it also works very well on B.40, .40LA, .46LA, Aero Tiger .36...and probably more. By the bag, they're about $2 each.  ;D Steve
« Reply #16 on: March 10, 2010, 09:17:29 AM »
AHHH So true old Wise one...BUT there not WOOD!
Scott Riese
Portland, Oregon
AMA 528301
Offline David Shad
« Reply #17 on: March 10, 2010, 11:34:47 AM »
Where are we getting the TT props.
Big Dave AMA 80235
Offline Scott Hartford
« Reply #18 on: March 10, 2010, 11:41:26 AM »
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #19 on: March 12, 2010, 03:31:31 PM »
You left out Rev-Up EW series, which I liked a lot for CL Stunt, which would naturally work well for sport flying too. I had pretty good luck with a Zinger on a ST .51 as well.
L.
"Don't be so humble. You're not that great." -Golda Meir
Offline Clayton Berry
  • Grey haired kid to be wary of
« Reply #20 on: March 12, 2010, 07:34:42 PM »
Phil
Mexican food spewed across the table.  I usually only laugh in the bedroom, but tonite I make the exception.  But, why are all of these other people laughing?
Ah, I figgered it out.  26 inches of Bolly.  In the bedroom.
Makes as much sense as dropping $20 for some rice and beans and dead flesh when I probably have a can of Spam in the pantry.  Probably don't have any chips or cheese, though.
Clayton - forever busy committing random acts of coolness
« Reply #21 on: March 13, 2010, 01:09:33 PM »
I'll take plastic, if I find one that really works well. They are more consistent, cheaper and hold up better to those grass trimming takeoffs. I don't care about the weight (of the prop)...I can adjust the CG to compensate. Thrust and line tension are the things I'm looking for. The heavier props help starting, too.  #^  Steve
« Last Edit: March 13, 2010, 09:46:08 PM by Steve Helmick »
Offline Jim Oliver
« Reply #22 on: March 15, 2010, 05:45:54 PM »
I have had good results from the Xoar line of props.  Got mine from   www.abellrc.com
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #23 on: March 16, 2010, 04:19:24 PM »
I just went and looked at the list to see why I hadn't voted.  You don't have my props listed.  I use Top Flite Power Points as they are readily available.  The alternative is the wood Master Airscrew.  Then followed by Zinger.   D>K H^^
« Reply #24 on: March 16, 2010, 05:48:36 PM »
Doc is right...the TF Power Point props are not a bad piece, IF they make the size you need. The 10-4 works ok on a .25LA, and the 11-4 works ok on a Magnum XLS .36. Regarding the 11-4, it worked about the same as a Master Airscrew 11-4 S-2 Scimitar (plastic fantastic). NOT as well as the Thunder Tiger Cyclone 11 x 4.5 by quite a bunch, however.  Having fun at VSC, Doc?  H^^ Steve
Offline Steve Holt
« Reply #25 on: March 16, 2010, 08:32:52 PM »
The RSM props are from Xoar and they are near perfect as delivered.  They really perform better than any of the wood props and near what a carbon fiber prop will deliver.  This is near the perfect prop for a good Fox 35 or Max S 35.  My  Byron Barker modified Thunder Tiger 36 also really performs with the RSM prop.  This is not a good choice for an engine running at a fast 2 stroke, but for most stunt engines it is really great.
