  • July 03, 2025, 02:41:33 AM
Author Topic: Best Position For Plane Storage  (Read 2344 times)
Offline Dick Fowler
« on: January 14, 2008, 03:57:24 PM »
Over the years I've heard some unusual and sometimes compelling arguments for how people store their planes. Most are concerned about the engine bearings. So how do you guys do it and why?
Nose Up... nose down.... level or none of these.
Dick Fowler AMA 144077
Kent, OH
Re: Best Position For Plane Storage
« Reply #1 on: January 14, 2008, 04:07:35 PM »
Dick,
Planes are level, but the engines are out for storage so I suppose it doesn't matter.
« Reply #2 on: January 14, 2008, 06:12:37 PM »
I hang mine from the tail on the wall, nose down. Takes alot of space but oil drips out the front rather than down the whole fuse.
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #3 on: January 14, 2008, 06:55:25 PM »
Best thing I have had luck with is to apply after run oil and then wrap the engine in a plastic bag!
You gonna get a lot of ideas on this one!
Terry B.
Offline Shultzie
« Reply #4 on: January 14, 2008, 07:06:52 PM »
Uhhh...Depending on the brand of wheels....for example, My old SuperChip...started having flat spots on the tires (from hanging by the tail nose down:) ...and I had to place a piece of old balsa scrap into the wheel pant to lift it off the wall slightly.
The last time I flew off a parking lot....I noticed after the touch down landing the weird little fluttering sound that I mistakenly thought was a wheel about to fall off. LL~
Don Shultz
« Reply #5 on: January 14, 2008, 07:52:04 PM »
Yes, that can be a problem if you let them sit for a long time on foam wheels. I occasionally spin the wheels.
Offline Ward Van Duzer
« Reply #6 on: January 15, 2008, 08:47:50 AM »
I hang my piped ships nose up, by the L.G. to allow the pipe to drain. Others by the tail wheel.
Ward
« Reply #7 on: January 15, 2008, 10:29:40 PM »
Nose down on stunt ships with inverted engine,  and either nose down or in normal position with side mounted engine profile and combat ships.
Offline Andrew Borgogna
  • Andy
« Reply #8 on: January 16, 2008, 05:00:39 PM »
I was told years ago that with a plane bearing engine nose up or down does not much matter, but with a ball bearing engine always nose up to allow all the liquids to drain down and away from the bearings.  Now do I follow these rules, ah no.
Andy
Andrew B. Borgogna
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #9 on: January 16, 2008, 08:25:27 PM »
I hang mine by the lead out lines.  My father and I have been doing it that way for over 60 years combined, no ill-effects.   8)
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
Offline Leo Mehl
« Reply #10 on: January 17, 2008, 02:31:31 PM »
I store mine upstairs far from the shop. mw~ mw~ mw~ mw~ mw~ mw~ HB~>
« Reply #11 on: January 17, 2008, 03:35:54 PM »
Hey Leo, is that where your wife sends you when you're bad?
« Reply #12 on: January 17, 2008, 06:12:51 PM »
Look at the tail end of the section on show us your shop and you will see my planes hung in any manner that will get them off the floor.  DOC Holliday
Offline Joey Mathison 9806
« Reply #13 on: January 17, 2008, 06:43:16 PM »
as ward stated the crud in your pipe  needs to stay out of your engine. that is how they should be hung.ex. down
200 mph man ama#9806 joey mathison
Offline Leo Mehl
« Reply #14 on: January 18, 2008, 05:42:16 PM »
She usually sends me there for any reason at all. I go just to save this marriage.You know for better or worse. mw~ mw~ mw~ mw~ mw~ mw~ HB~>
