  • June 24, 2025, 04:42:38 AM
Author Topic: Hurricane arrived  (Read 1571 times)
Offline mike hartung
  • aeronut
Hurricane arrived
« on: March 30, 2010, 09:02:03 AM »
Hello guys and gals I recieved my Sea Hurricane in the mail today; thanks very much. I thought you might like to see the Yak-9 that I just completed.
blue skys and tail winds to all.
Offline billbyles
Re: Hurricane arrived
« Reply #1 on: March 30, 2010, 09:11:24 AM »
YEAH!!  Yak 9s forever!  I still have the one I built in 1994 & it is still flying (just to keep Keith Trostle on his toes.)  Mine is very high-tech with an L&J Fox .35 & a beat-up original Y&O 10-6 prop...well, maybe not so high-tech but fun anyway.  The Yak is a replica of the one I built & flew when I was in high school and I just had to have another one.
Bill Byles
AMA 20913
So. Cal.
  • aeronut
« Reply #2 on: March 30, 2010, 09:33:18 AM »
Yup Bill my first Yak-9 build was 48yrs ago. n~
Offline Dalton Hammett
« Reply #3 on: March 30, 2010, 02:45:51 PM »
    That looks extremely nice..........
DH
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline Terrence Durrill
« Reply #4 on: March 30, 2010, 05:51:33 PM »
That is a great looking Yak-9.  Is that from a Sterling kit or another manufacturer?  I started C/L in1953, but didn't get to build a Yak until 1987.  I fly the Yak with Foxes, .35 stunt, .29 stunt and .25 stunt engines.  In 1987, I found a hobby shop going out of business and there were 6 Sterling Yak-9 kits on the shelf.  Knowing that Sterling was also closing up shop and the Yak-9 was going to be a classic kit in the future, I bought them all.  So far, I have only built one , but I have started a second one.  I don't know if I will get them all built before the call to the great circle in the sky, but, the Yak-9 is one of my favorite sport planes.   H^^
Offline billbyles
« Reply #5 on: March 30, 2010, 07:26:11 PM »
When I built my current Yak 9 in 1994 I used the original Sterling kit for patterns and supplied my own wood.  The wood in my Sterling kit is just too heavy; for example, the kit fuselage blank as it came in the kit weighs right at 6 ounces.  The fuselage that I made ended up weighing 3 1/2 ounces including motor mounts, doublers, scoop & canopy.  I cut the middle out of the blank up to under the canopy, added a balsa stick truss in the cutout area, and sheeted the sides with 1/16" balsa with carbon fiber strips (.007"x1/4" wide) under the sheeting at the top & bottom.   The rest of the kit wood was replaced also as it was equally as heavy.  The finished airplane weighs 25 ounces with a metal tank & Fox .35, which is not super lightweight but a lot lighter than if I had used the kit wood.  The finished fuselage is quite stiff torsionally and has flown all these years without any structural problems.  The main problem my Yak 9 has had is that about two years after I finished it guys started building much better flying OTS airplanes so my brief run of OTS trophies came to an end.
Bill Byles
Bill Byles
AMA 20913
So. Cal.
« Reply #6 on: March 31, 2010, 05:50:18 AM »
I had one Sterling Yak 9 that I did with the flaps.  Leaned the engine out and fly.  Did not know about it being overweight or bad wood because it would do all the loops, eights and inverted I wanted to do.  I let some kid have it later in life that was getting into CL. #^ #^ H^^
  • aeronut
« Reply #7 on: March 31, 2010, 10:55:33 AM »
Thanks for the kind words about the Yak-9 guys. It was a Brodak kit and the wing is a lot differant constrution than the old Sterling kits with better wood than Sterling also. Just the same I still remember having a really good time with those Sterling kits back in the early 60's. Tight lines to you.
« Reply #8 on: March 31, 2010, 04:06:15 PM »
Someone needs to come out with a kit like one of the first I had.  All printed wood.  Instructions say cut out side the line and then sand to fit.  Die crunchong put us in seventh heaven. H^^
