  • July 18, 2025, 10:02:13 AM
Author Topic: Bellcrank Rod Placement  (Read 650 times)
Offline Casey
« on: April 21, 2019, 11:45:22 PM »
Hi Guys
Which method is more durable for big stunters?
Installing the bellcrank rod in line with the vertical lite-ply spar so that the vertical lite-ply spar can also help in absorbing some of the flight and pull test stresses)
or
installing the bellcrank rod just behind the vertical lite-ply spar.
Of course, 2 plywood plates - one on top and one on the bottom will also be fitted between the fuselage sides and over the bellcrank rod to complete the bellcrank mount.
Offline Perry Rose
Re: Bellcrank Rod Placement
« Reply #1 on: April 22, 2019, 05:24:39 AM »
Pic No. 1 if I have the chance. But I've done it both ways with no problems. I use  a rod with a Z bend or L bend and collar on the bellcrank and a threaded coupler/clevis at the flaps. Less trouble and less friction.
