  • June 23, 2025, 05:08:39 AM
Author Topic: Super Tigre G-61 Dimensions?  (Read 874 times)
Offline Steve Riebe
« on: September 23, 2018, 08:29:41 AM »
Can anyone please advise of the mounting bolt pattern and the C/L to prop drive washer? Is the 61 the same footprint as the G51? Thanks for any help!
Offline George Truett
Re: Super Tigre G-61 Dimensions?
« Reply #1 on: September 23, 2018, 11:35:45 AM »
Here's ST G 61, not sure it it's the engine you have.
Offline Steve Riebe
« Reply #2 on: September 23, 2018, 02:08:54 PM »
Thanks George, your diagram made it possible to determine the right size engine for a plane I just acquired. The 61 is a much bigger footprint then the 51 which looks like it will fit.
Offline richardhfcl
  • AMA 82448
« Reply #3 on: September 23, 2018, 05:12:25 PM »
Steve,
     I brought out an S.T.-51 to the field this morning for you to trial fit to your new
airplane.  I'm just guessing that your plane was set up for that engine.
     'Catch you out at the field,
     Dick
Richard Ferrell
AMA 82448
