Can you guys feel a deleterious effect from a misaligned straight bellcrank, or do you just intuit that you would? I just did some crude ciphering using my control geometry program. With bellcrank deflection of about +/- 70 degrees, it looks like the straight bellcrank would give about .4 lb. of differential line tension at max control in either direction. Around neutral, though, the curve appears to flatten out, kinda like a cube function. What did you get from your calculation?
I wouldn't think there would be any perceptible destabilizing because this effect would add to hinge moment, and hinge moment would dominate around neutral control position. Mind you, I haven't calculated or measured hinge moment, so I don't know the relative magnitudes of this bellcrank effect and hinge moment on differential line tension. I'd be inclined to use a self-decentering bellcrank to counter hinge moment, but the bellcrank effect increases proportional to line tension, which is opposite of what you'd like it to do to counter hinge moment. Thanks for bringing this up (again, in Brett's case). I shall fuss with it more before making the bellcrank for my next dog.
